oblivion
- Delivery Options
- Local Pickup Only
First up is a Macintosh 9600/200. working and in cosmetically decent condition with a few scuffs and scratches but not too much yellowing. has 6 PCI slots making it the most expandable classic Mac. I had it running fine with OS 8 but I did remove the hard drive so you're getting just the computer, no hard drive, mouse, or keyboard. has the 200mhz power PC CPU, 96MB of RAM (capable of 1.5GB total memory), and a twin-turbo video card.
$100 local pickup only, I'm located in Apache Junction, AZ but it may be possible to arrange meeting up someplace closer to Tempe/Mesa/Chandler area
Next up is a fully working Tandy 1000EX. The Tandy is boxed but comes with no documentation, the CM-5 RGB monitor is unboxed. both are tested and working fine. 1000EX is in great cosmetic condition and comes with a modem card and official memory/DMA controller PLUS card maxing the memory to 640k and adding DMA support. CPU is an 8088 running at 7MHz downclockable to 4.77MHz. does not come with any software so you'll need DOS on a 5 1/4 floppy to get very far or I hear they make compact flash HDD PLUS cards now, so there's that. floppy drive tested working as well as internal sound/speaker.
CM-5 RGB monitor works fine but is cosmetically a bit beat up with scuffs, scratches (not on the screen), and some yellowing but seems to display fine. The bezel door on the monitor has a broken thing so It will stay on but is prone to fall off. Probably fixable with the baking soda/super glue trick or a 3D-printed replacement.
$300 local pickup only - I'm in Apache Junction, AZ but I may be able to meetup in the Tempe/Mesa/Chandler area if that works better.
