Stone
10k Member
Either that or no HD and two floppies!!!If you want originality in your system then you should be using MFM hard disk and controller!!
Just buy it, put it together and quit worrying about the freaking color. This is a quality product that works great. Color makes NO difference to the performance. If you want originality in your system then you should be using MFM hard disk and controller!!
Lo-tech 8-bit IDE adapter is green... And faster too
Edit: I answer myself, BIOS is obviously empty
Just a minor problem, the kit comes with a pair of 12K resistors when suposedly (by looking the PCB), 10K resistors are needed. Is it intended?.
At least it has worked with 10K resistors; so definitely seems that these 12K resistor were a packaging error. @glitch?
No error, you can use any value from 2.2K - 47K. I included 12K in some of the kits, 10K in others. Just depends on whether Amy or I packed the kit The 10Ks were either 5% carbon film or 1% Dale RN55 mil-spec resistors, I think the 12Ks were all 5% metal film. Some of the assembled boards use 4.64K, some use 10K, some use 12K. It's just a pull-up so the value is totally noncritical.
Likewise, the 470 Ohm resistor is just a current limiter for the LEDs, though all of the kits have shipped with 470 Ohm resistors. Some are 5% green metal film, some are 5% tan carbon film, and some are 1% blue metal film.
