Starshadow
I just swapped out a 68lc040 cpu and relaced it with a full 040 in a Performa 475. Does the full 040 produce anymore heat than the LC040? I was wondering If I need to put a heat sink on the cpu somehow , or does the case still allow enough airflow to keep things from overheating?
I did notice it runs a good bit faster with the full 040.
This was basically my project to build a Hot Rod Mac LC class. I already have a 32 mb ram chip in it and I found a 1 gig scsi hd that will fit, and I have a 4 gig later style scisi with a pin adapter that has been tested and does drop down to the older scsi mode, and has a minimal OS on it( the old copy the system folder off the floppy to the hd trick)
