I've got an old 486 laptop that I'm wanting to get on the internet. I've never successfully set up a DOS machine on the net, so I'm not quite sure what to look for when it comes to the settings. I tested the hardware in my Windows laptop, so I know that end of it works fine. I'm using a 3Com EtherLink III card, Model 3C562C/3C563C on a Toshiba Satellite 110CS
Here's what happens when the Ethernet driver loads up:
Here's what happens when the Packet Driver is loaded:
When I try firing up Arachne, it find the packet driver, but can't connect to the internet.
I tried installing the Card Services for this laptop. The Ethernet driver finds Card Services, but the packet driver does not.
Does anyone have an idea of what's going wrong here?
No Card Services found. Enabler is being used
A Etherlink III+ Modem PC Card is Detected
Current Card Configuration:
LAN IO Port = 300h Lan IRQ = A COM = LANONLY
Card State : UseEnabler
PC Card Configuration Manager is loaded.
Warning: 3C589 could not be configured using Card Services.
No Card Services or Card Services is not responding
Driver will now try to enable 3C589 using PCMCIA host hardware.
3C589 configuration using hardware enabler succeeded.
I/O Base: 768 (0x300)
Interrupt: 10 (0x0)
Transceiver: Twisted Pair (100aseT)
Ethernet Address: 00:00:00:00:00:00
Packet Driver Interrupt: 96 (0x60)
