Hi, this is my first forum post so forgive me if I do anything incorrect.
My brother acquired a Tandy 1000 SX and the insides was a rats nest with stuffing in it along with some corrosion. It still started up! I took it apart to try and clean it up a bit, but after putting it back together I am having a issue getting the floppy drives to work. When it starts up it doesn't have that floppy sound from both drives, the A: drive lights up and you can hear it spinning at a slow speed. It seems to try and read but doesn't physically read the disk. It then asks for a system disk. I have verified both floppy drives work in a different Tandy 1000 SX as well as the cable. I also tried different working floppy drives and cable on the broken machine and it does the same thing. I have reseated the FDC chips and that didn't change anything. I have ordered new FDC chips (UPD765AC and FDC9216) and they should arrive in a week. I'm not sure if that is the issue though because I have tried the same chips from a working Tandy 1000 SX and it still didn't work. The drives did work before I cleaned it so I'm guessing I did something to it. I have gotten a XT-IDE card to work on the machine and boot to DOS so I know the machine still works.
Thinking the on board Floppy Controller may be bad I bought a WD1002A-WX1 to see if I could turn it into a Floppy Disk Controller (I read on a forum post that it was possible). I followed the instructions to get the card to read IRQ 2 and I hooked up the 34 pin cable from J1 on the hard card to the floppy drives. This causes the drives to either stay lit or cause a 1701 on the startup screen. I have a feeling I am missing something (just being an amateur here). Would I need to use the 20 pin J2 and J3 ports as well to get the floppy drives to work? I have turned dip switch 2 off on the motherboard and that didn't change anything.
I just would like to get the floppy drives to work again so I can give this machine back to my brother fully working, so if there is a way to not use the hard card or use it I'm open to any suggestions. Is there other things on the motherboard that would inhibit the floppy drives to work? Capacitors or different chips?
I have spent a lot of time on this and any help would be appreciated. Thanks!
