I assume you mean your horizontal shaft engine is bad and you want to use a 3.5hp lawn mower engine or something. If that is the case, you will HAVE to save up for a horizontal shaft engine. There is no way to convert a go kart that uses a horizontal shaft engine to a vertical shaft.
