carangil
Does this laptop have sound? If not, I would recommend picking up a pcmcia card with good sb emulation. These are often bundled with various external CDROM options.
My other suggestion, is even though it may have a working floppy drive, is to find a way to load software onto it without using a floppy. Either a pcmcia ethernet card, or using a null modem cable. Being prepared for either a dead floppy drive or a dead boot disk is very important. Remember, even when your floppy drive is completely dead, you always have the option of removing the hd and mounting it in a pc (or externally) and putting a minimal boot image on it. When I put my 486 desktop together about 2 years ago, I had no working dos floppy, and the floppy drive in my more modern PC was on its way out. You could put the 486's drive in an external enclosure to copy files to it, but sometimes its hard to make it a proper bootable drive. Especially making a fat16 bootable drive from inside of a modern OS.
I did this:
-Install DOS and Win 3.1 floppy images into Bochs (a good emulator you should google if you don't know)
-Make a boot disk image inside Bochs (with format a: /s ).
-Make a bootable cd from the floppy image. (You can get these premade on the internet as well. Dos 6.22, Win95 or Win98 'dos' boot cd should work)
-Boot modern PC desktop up the dos boot cd you just made. Do it with its own HDD disconnected, with the intended 486 hdd plugged in.
-From the modern PC's 'a:' drive (which is really a floppy emulated off the cd), fdisk the 486's drive, and then format /s c:
Now that the 486 drive is properly bootable, you can:
-Turn off modern PC and reconnect it's own drive. Boot with 486's drive attached (as the 'd' drive), or put 486 drive in an enclosure
-Copy all the other files from the Bochs image onto the drive This is also where you want to take advantage of the opportunity to copy on installers for all the games or drivers you will want.
-Put 486's drive back into the 486. It's now bootable and loaded with everything.
I did this:
