antiquekid3
This power supply has come up a few times recently in Rainbows. I have one in a DECmate II. I've had the computer for a while and remember it had power supply issues, mostly because I had removed the power supply.
It blows the internal breaker almost immediately upon powering it up with 6W loads on the +5V and +12V rails. I eventually took the PCB out from the enclosure and started doing some more detailed probing with the Fluke, given a visual inspection turned up nothing.
I got to the main switching transistor, a BUV48A, and found that all three terminals appear quite shorted. Even though the schematic seemed to show that there is nothing of sufficiently low resistance between the terminals to cause my Fluke to read quite low, I pulled it out and confirmed my suspicion.
I guess I'll order another one of these, but I'm nervous about putting a new one in if this was not the cause, but merely another symptom. Any thoughts?
Here's a photo before I dusted it out. Not the worst I've seen, but certainly not the cleanest either.
