At the moment i have a working SCP 8086 System on my bench.
It contains the 8086 CPU board SCP-210, two 64K Memory boards SCP-110, two 32K Memory boards CompuPro RAM-20,
one Tarbell MD2022 Double Density floppy controller, one CPU Support board SCP-301 and the 4-channel serial bord SCP-400.
I am able to boot MS-DOS 1.25 and 2.0 from a 8" floppy drive.
The next step is to integrate a hard disk in the system.
I ask Tim Paterson, but he is afraid that he can not help me.
Which hard disk controllers and what drivers are used for the S-100 systems in these days?
Is there any documentation from SCP for the integration of a hard disk still existent?
These hard disk controller may be used in the SCP Gazelle system.
Underneath is a hard disk device driver that i found on one of the MS-DOS 2.0 disks. For what controller it may be?
Frank
Frank
; Hard disk I/O for MS-DOS 2.0
PAGE 60,132
INCLUDE IODEF.ASM
IO GROUP CODE
CODE SEGMENT BYTE PUBLIC 'IOSYS'
ASSUME CS:IO, DS:IO
IF INSTALL
HDSKDEV: ;Header for hard disk
DD -1
DW 2000H
DW STRATEGY
DW HDSK$IN
DB ?
ELSE
PUBLIC HDSKTBL
EXTRN EXIT:NEAR, CMDERR:NEAR, BUS$EXIT:NEAR, PTRSAV:DWORD
ENDIF
HDSKTBL:
DW HDSK$INIT
DW HARDCHG
DW GET$HBPB
DW CMDERR
DW HARDREAD
DW BUS$EXIT
DW EXIT
DW EXIT
DW HARDWRITE
DW HARDWRITE
DIRENT EQU 96
ALLOCSIZ EQU 4
FATSIZ EQU 6
IF IMI
NHEADS EQU 6 ; Number of heads
NSECT EQU 8 ; Number of sectors per track
NTRACKS EQU 306 ; Number of cylinders
LOWCURTRK EQU 0 ; First track of low write current
PRECOMTRK EQU 256 ; First track to set precomp bit
ENDIF
IF SCRIBE
NHEADS EQU 4 ; Number of heads
NTRACKS EQU 480 ; Number of cylinders
PRECOMTRK EQU 0 ; First track to set precomp bit
ENDIF
RESETHDC EQU 54H
STARTHDC EQU 55H
HARDRDOP EQU 0
HARDWROP EQU 1
RETRY EQU 3 ; # of times to try disk command
TIMEOUT EQU 10 ; 0.2 sec/loop--set 2 seconds for 10 MHZ CPU
HDCPARAM:
HDIR DB 0 ; Direction
HSTEP DW 1 ; Amount to step
HDRIVE DB 0DCH ; Drive/head select
DMAAD DW 0 ; DMA address
DMAHI DB 0
ARG1:
HCYL DW -1 ; Current cylinder
HHEAD DB 0 ; Current head
HSECT DB 0 ; Current sector
OPCODE DB 0 ; Read/write code
HSTAT DB 0 ; Return status
IF INSTALL
NEXTAD DW HDCPARAM
ELSE
NEXTAD DW HDCPARAM+10H*BIOSSEG
ENDIF
NEXTADHI DB 0
IF INSTALL
PTRSAV DD 0
STRATP PROC FAR
STRATEGY:
MOV WORD PTR CS:[PTRSAV],BX
MOV WORD PTR CS:[PTRSAV+2],ES
RET
STRATP ENDP
HDSK$IN:
PUSH SI
MOV SI,OFFSET IO:HDSKTBL
DISPATCH PROC FAR
ENTRY:
PUSH AX
PUSH CX
PUSH DX
PUSH DI
PUSH BP
PUSH DS
PUSH ES
PUSH BX
LDS BX,CS:[PTRSAV] ;GET POINTER TO I/O PACKET
MOV AL,[BX.UNIT] ;AL = UNIT CODE
MOV AH,[BX.MEDIA] ;AH = MEDIA DESCRIP
MOV CX,[BX.COUNT] ;CX = COUNT
MOV DX,[BX.START] ;DX = START SECTOR
XCHG DI,AX
MOV AL,[BX.CMD]
XOR AH,AH
ADD SI,AX
ADD SI,AX
CMP AL,11
JA CMDERR
XCHG AX,DI
LES DI,[BX.TRANS]
PUSH CS
POP DS
CALL [SI] ;GO DO COMMAND
LDS BX,CS:[PTRSAV]
MOV [BX.STATUS],AX ;MARK OPERATION COMPLETE
SUB [BX.COUNT],CX ;Subtract amount transfered
POP BX
POP ES
POP DS
POP BP
POP DI
POP DX
POP CX
POP AX
POP SI
RET ;RESTORE REGS AND RETURN
DISPATCH ENDP
; Standard return types
EXIT:
XOR CX,CX ;Transfer complete
MOV AH,00000001B ;All done
RET
BUS$EXIT: ;DEVICE BUSY EXIT
MOV AH,00000011B
RET
CMDERR:
MOV AL,3 ;UNKNOWN COMMAND ERROR
MOV AH,10000001B ;MARK ERROR RETURN
RET
ENDIF
HARDCHG:
LDS BX,[PTRSAV]
MOV BYTE PTR [BX.TRANS],1 ;Disk not changed
JMP EXIT
HARDREAD:
MOV OPCODE,HARDRDOP
JMP SHORT HARDIO
HARDWRITE:
MOV OPCODE,HARDWROP
HARDIO:
PUSH DS
XOR SI,SI
MOV BP,[NEXTAD]
MOV AL,[NEXTADHI]
MOV DS,SI
MOV WORD PTR [SI+50H],BP
MOV BYTE PTR [SI+52H],AL
OUT RESETHDC,AL ; Reset hard disk controller
POP DS
MOV AX,ES
SHL AX,1
RCL SI,1
SHL AX,1
RCL SI,1
SHL AX,1
RCL SI,1
SHL AX,1
RCL SI,1
ADD AX,DI
MOV DMAAD,AX
XCHG AX,SI
ADC AL,0
MOV DMAHI,AL
CMP HCYL,-1 ; Is current track invalid?
JNZ COMPPOS
CALL RESTORE ; Home disk head
COMPPOS:
PUSH DX
MOV SI,NSECT ; Sector/track on hard disk
XCHG AX,DX
XOR DX,DX
DIV SI ; AX=track, DX=sector
INC DX ; Sector numbers start with 1
MOV HSECT,DL
MOV SI,NHEADS
XOR DX,DX
DIV SI ; AX=cylinder, DX=head
MOV HHEAD,DL
SHL DL,1
SHL DL,1
NOT DL
AND DL,9CH
CMP AX,PRECOMTRK
JB SAVHEAD1
OR DL,80H ; Turn on precomp
SAVHEAD1:
CMP AX,LOWCURTRK ; Need low write current?
JAE SAVHEAD
OR DL,40H ; Turn off low write current
SAVHEAD:
MOV HDRIVE,DL ; Drive/head select byte
MOV DX,AX
XCHG HCYL,AX ; Set current cyl, get previous
SUB DX,AX ; Amount to move
MOV AL,0 ; Assume movement IN
JAE HAVSTEP
NEG DX ; Get absolute value
MOV AL,10H ; Set movement OUT
HAVSTEP:
MOV HDIR,AL
MOV HSTEP,DX
POP DX ; BX,CX,DX have orignal command parameters
; All set for hard disk operation!
HARDREADWRITE:
MOV AH,RETRY ; Retry count
HCOM:
CALL HDCCOM
JNZ NOTNEXT ; If not successful, don't bump to next sector
ADD DMAAD,1024
ADC DMAHI,0
INC DX
MOV AL,HSECT
INC AL
CMP AL,NSECT+1 ; Stay on this track?
MOV HSECT,AL
LOOPNZ HARDREADWRITE
JCXZ OKRET
JMP COMPPOS ; Re-compute everything
OKRET:
MOV AH,1 ;No error
RET
NOTNEXT:
CMP AL,1 ; Is drive not ready?
JBE HARDERR ; Don't retry if not ready or time out
DEC AH
JNZ HCOM
; Hard disk error on hard disk. AL has the error code. Convert disk
; error code to MSDOS 2.0 error code
HARDERR:
MOV HCYL,-1 ; Force restore next time
CMP AL,10 ; Is it a reasonable error code?
JB NEXT1
MOV AL,0 ; General disk failure
NEXT1:
MOV BX,OFFSET IO:ERRTAB ; Set DOS error table
XLAT
MOV AH,81H ; ERROR
RET ; CX = number of sectors to go
ERRTAB:
DB 12 ; General failure
DB 2 ; Drive not ready
DB 12
DB 12
DB 8 ; Sector not found
DB 8 ; Data not found
DB 12 ; Data overrun
DB 4 ; Data CRC error
DB 10 ; Write fault
DB 4 ; Header CRC error
;Restore head on hard disk.
RESTORE:
MOV ARG1+1,30 ; 3 ms step time, no head settle delay
MOV AX,7+100H*4 ; 1024 byte sector, LOAD CONSTANTS command
XCHG AX,ARG1+3 ; Previous opcode in AH
MOV BL,1
CALL QUICKCOM ; Execute command
JNZ EXITREST ; Abort if controller failure
MOV ARG1+1,0 ; Set to fast step (after restore)
MOV HSTEP,0FFFH ; Maximum number of steps
MOV HDIR,10H ; Step out
CALL HDCCOM ; Restore and set fast seek
MOV HCYL,0 ; Now on track zero
EXITREST:
MOV OPCODE,AH
RET
HDCCOM:
MOV BL,TIMEOUT
QUICKCOM:
PUSH CX
XOR CX,CX
MOV HSTAT,0
OUT STARTHDC,AL
HWAIT:
MOV AL,HSTAT
OR AL,AL
LOOPZ HWAIT ; Try for 2 seconds
JNZ HRET
DEC BL
JNZ HWAIT
HRET:
POP CX
MOV HSTEP,0
CMP AL,-1
RET
GET$HBPB:
; Set up BPB for Hard disk controller. Real simple isn't it?
MOV SI,OFFSET IO:HARDDRIVE ; Hard disk Parm table
SETBPB:
LDS BX,[PTRSAV]
MOV [BX.MEDIA],1 ;One hard disk
MOV [BX.COUNT],SI
MOV [BX.COUNT+2],CS
JMP EXIT
HINITTAB:
DW HARDDRIVE
HARDDRIVE:
DW 1024 ; Sector size
DB ALLOCSIZ ; Allocation unit
DW 1 ; Reserved sectors
DB 2
DW DIRENT ; Directory entries
DW NSECT*NHEADS*NTRACKS
DB 1 ; Media descriptor
DW FATSIZ ; Number of sectors for 1 Fat
BREAK LABEL BYTE ; Break address
; Code below this point is thrown away for installable versions
HDSK$INIT:
IF INSTALL
MOV AX,CS
MOV BX,AX
MOV CL,4
SHL AX,CL
ROL BX,CL
AND BL,0FH
ADD [NEXTAD],AX
ADC [NEXTADHI],BL
LDS BX,[PTRSAV]
MOV WORD PTR [BX.TRANS],OFFSET IO:BREAK
MOV WORD PTR [BX.TRANS+2],CS
PUSH CS
POP DS
ENDIF
MOV SI,OFFSET IO:HINITTAB
JMP SETBPB
CODE ENDS
END
