VERAULT
I bought an original 1982 board model non-enhanced apple IIe which was supposed to be non-working for a really fair price. Reason I bought it was all the cards it came with:
An Echo Plus Speech synth card by Street Electronics Corp 1984
An DRUM-KEY Drum Synth Card by Peripheral Visions Inc. 1984
Apple Mouse interface card
Paddle Adapple Combo board for hooking up #2 joystick
Standard Disk II interface card (no photo needed)
But here is one that really has me intrigued. Its is a Kaga-Taxan RGB II-B card model 410-07 from 1983. From what little I can find this is a digital RBG card capable of sending utilizing digital rgb monitors.
The video out cable has been sliced to I need to find the pinout and make a new connector.
The red soldered wire on the card runs to a connector that is plugged into J13 pin 2 (which is usually for the video modulator)
2 wires coming off of cn3 are soldered to legs 7 and 8 of an 74166 on the logic board at location F5.
at IC5 on the card which is a 74LS74AP someone has crudely soldered on pin header to leg #11
CN2 on the card has no cable and only pins 2 and 3 as if pin 1 was omitted or removed.
cn1 on the card is the video connector with 5 wires
there is a 3 pin jumper which lets you set either II or IIe (its set to IIe). The card is in socket 7. The only fingers on the edge connector are 19,23,24,25,26, and 35.
The only mod to the board besides the wires running to the 74166 is that the X7 jumper pads on the logic board have been bridged ( I always wondered the uses of all those X jumper pads)
Id really love to try and get this card working on a digital RGB monitor so any help or knowledge on the card would be appreciated.
The kyboard also has key overlay stickers as seen here:
With those stickers, the drum and speech synth cards and the RGB card I really wonder what the use of this machine was.
By the way, the IIe works just fine. Dont know why they said it was non-working.
