Ec1564
I found this web site and made me boot up my old Tandy 1000 TL and TL/2! Well the TL booted up fine, but the TL/2 the HDD failed. I had a 2nd HDD of the same type:"WD93028-1 20Mb" but found that one had a bad control PCB.
I since tried several other under 45Mb Hdd's(ST-157a 44MB and Maxtor 8051A 42MB) and can not the the TL/2 to boot or even FDISK them. The limited setupTL2 program can only turn off the HDD chip on the MB. I since used a 8bit XT IDE hdd card controller to boot up using a CF to IDE adaptor and a 16Mb CF card(works really good!). But the TL/2 still will not acknowlage the other HDD's or the CF card on its own IDE port. The original HDD the partition table failed and I only get errors trying to write the system files making the HDD unusable.
Is there any special way the TL/2 look for the HDDs on the IDE port?
Eddie
Eddie
