Help Finding Typing Program from early 80s
Tincanalley
Los Angeles, CA
Okay, I've done all the searches I can think of, but can't see to find the typing program I learned to type on back in '85 on an IBM XT. I know it wasn't the simple one that used to come with the 5150. I am trying my best to remember exactly what it looked like. It had a keyboard layout on the bottom of the screen and a typing window above that. It would first teach you were the keys were and drill you on those. Then it would test you speed and accuracy and come up with drill based on your weaknesses. It wasn't anything fancy, but I always wanted a copy of it for my 5150.
Going by the year, I don't think it could have been a Mavis one. Typing Tutor doesn't look as I remember the program I used.
Tincanalley
Los Angeles, CA
Mavis came out 2 years after I learned. The program I used was no later than '85 and could have been back as far as 82 or so.
twolazy
Chicago, IL
Hopefully that TESS listing will help, since it was most likely educationalware... Hard part will be tracking them down. Archive.org has most stuff I look for, XT to AT wise.
hargle
minneapolis, MN
Typing Tutor III by Simon and Schuster fit the bill timeframe wise (1984) as well as one called Personal Touch Typing by CPT in 1985.
The CPT one had a "fun" space invaders/missle command kind of theme where letters had to be blasted out of the sky.
Tincanalley
Los Angeles, CA
Tincanalley
Los Angeles, CA
I'll check those out. Thanks!
Tincanalley
Los Angeles, CA
That looks interesting. I'm going to check it out. It isn't what I learned on as I would remember the fingers. The one I used would show the keys and highlight the key being pressed. I guess it's a bit of nostalgia for me as it is what I learned with. I'd like to get it and install it so I can brush up on my use of the original IBM keyboard as the layout is different enough from newer keyboards that I mess up quite a bit using shift and such.
ibmapc
Albany, OR USA
I don't remember if the fingers show up in all the modes. I think they are only displayed during the "training ground". I found it very helpful to see where my hands "should" be.
