gatewayrepairs1985
Hey @modem7,In my opinion, NiCd battery leakage [photo] is insidious. Look up the definition of that word to gain an appreciation of its meaning.
Have a very good inspection of your motherboard; the 'leakage' may have got to places that are well hidden.
See the motherboard at [here], one which suffered from such leakage on a card. Not only did the motherboard have a few faulty chips right near the card's slot, but there were damaged vias as well - you guessed it, around the general area of the slot. The green wiring is my bypassing of the faulty vias. No track damage. That motherboard would have probably stopped working at the time when the first chip, or via, was damaged. The remaining damage happened after that. The faulty chips near the card's slot suggested to me that the leakage worked its way into the chips.
I still have a friend's faulty IBM 5170 motherboard, from years ago. The battery had leaked, resulting in (indirect) damage to the area around the keyboard connector. That was repaired and then the motherboard worked. But only for a while. I suspect that even though I had thoroughly cleaned the affected area of the motherboard, that the 'leakage' had already made its way into bits (i.e. my cleaning affected the surface only). Something like that. It's just a hypothesis.
I am not saying that your symptoms are caused by damage resulting from NiCd battery leakage, but such damage is certainly a possibility.
You are seeing changing symptoms after physical influence is applied. Coincidence, or is this a damaged track/via/joint !
Maybe the Deoxit will be the fix.
Thanks for the information. Battery leakage is definitely insidious. I had a real close up inspection of my board with a magnifying glass and couldn’t find any hints of corrosion, battery leakage or broken traces.
