r WRDTR,CLKTR: 0x8200083f 0x40000000
r RQDC ,RFDC : 0x80000032 0x00000212
using eeprom values
using SMSJ ddr static values from serial eeprom
ddr init done
Running Normal Memtest...
Passed.
IOS Bootloader - Starting system.
FLASH CHIP: Numonyx P33
Checking for Over Erased blocks
Xmodem file system is available.
DDR values used from system serial eeprom.
WRDTR,CLKTR: 0x8200083f, 0x40000000
RQDC, RFDC : 0x80000032, 0x00000212
PCIE0: link is up.
PCIE0: VC0 is active
PCIE1: link is up.
PCIE1: VC0 is active
64bit PCIE devices
PCIEx: initialization done
flashfs[0]: 48 files, 9 directories
flashfs[0]: 0 orphaned files, 0 orphaned directories
flashfs[0]: Total bytes: 31739904
flashfs[0]: Bytes used: 13108224
flashfs[0]: Bytes available: 18631680
flashfs[0]: flashfs fsck took 10 seconds.
Reading cookie from system serial eeprom...Done
Base Ethernet MAC address: d8:67:d9:9d:06:c7
Waiting for PHY auto negotiation to complete... TIMEOUT !
Ethernet link is down.
Error: RGMII speed
The system has encountered an error initializing
the Ethernet port.
The system is ignoring the error and continuing to boot.
If you abort the system boot process, the following
commands will re-initialize Ethernet, TFTP, and finish
loading the operating system software:
ether_init
tftp_init
boot
Loading "flash:/ap3g1-k9w8-mx.ap_o_v15t_esc.201412101724/ap3g1-k9w8-mx.ap_o_v15t_esc.201412101724"...#################
File "flash:/ap3g1-k9w8-mx.ap_o_v15t_esc.201412101724/ap3g1-k9w8-mx.ap_o_v15t_esc.201412101724" uncompressed and installed, entry point: 0x4000
executing...
enet halted
IOS Secondary Bootloader - Starting system.
PCIE0: link is up.
PCIE1: link is up.
Radio 0 : Vendor 0x11AB, Device 0x8350
64bit PCIE devices
Radio 1 : Vendor 0x11AB, Device 0x8324
Creating Test Kernel diagnostic commands
Radio 0 : Vendor 0x11AB, Device 0x8324
Radio 1 : Vendor 0x11AB, Device 0x8350
Radio 2 : Vendor 0x7571, Device 0x5FF3
Radio 3 : Vendor 0xD455, Device 0xBFDF
******** AUTOMATIC DDR CALIBRATION UPGRADE LOGIC *********
=== 1. Is original FCS bootloader in BS:? If not, skip upgrade ===
---> original FCS bootloader not detected -- skip upgrade
Boot CMD: 'boot flash:/ap3g1-k9w8-mx.ap_o_v15t_esc.201412101724/ap3g1-k9w8-xx.ap_o_v15t_esc.201412101724;flash:/ap3g1-k9w8-mx.ap_o_v15t_esc.201412101724/ap3g1-k9w8-xx.ap_o_v15t_esc.201412101724'
Loading "flash:/ap3g1-k9w8-mx.ap_o_v15t_esc.201412101724/ap3g1-k9w8-xx.ap_o_v15t_esc.201412101724"...##############################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################
File "flash:/ap3g1-k9w8-mx.ap_o_v15t_esc.201412101724/ap3g1-k9w8-xx.ap_o_v15t_esc.201412101724" uncompressed and installed, entry point: 0x100000
executing...
Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
cisco Systems, Inc.
170 West Tasman Drive
San Jose, California 95134-1706
Cisco IOS Software, C3500 Software (AP3G1-K9W8-M), Experimental Version 15.2(20141211:014359) [wnbubld 121]
Copyright (c) 1986-2014 by Cisco Systems, Inc.
Compiled Wed 10-Dec-14 18:24 by wnbubld
Initializing flashfs...
flashfs[3]: 48 files, 9 directories
flashfs[3]: 0 orphaned files, 0 orphaned directories
flashfs[3]: Total bytes: 31481856
flashfs[3]: Bytes used: 13108224
flashfs[3]: Bytes available: 18373632
flashfs[3]: flashfs fsck took 7 seconds.
flashfs[3]: Initialization complete.
flashfs[4]: 0 files, 1 directories
flashfs[4]: 0 orphaned files, 0 orphaned directories
flashfs[4]: Total bytes: 11999232
flashfs[4]: Bytes used: 1024
flashfs[4]: Bytes available: 11998208
flashfs[4]: flashfs fsck took 0 seconds.
flashfs[4]: Initialization complete.
Copying radio files from flash: to ram:
Copy in progress...CCC
Uncompressing radio files...
...done Initializing flashfs.
Error: RGMII speed
Radio0 present 8364B 8000 B8020000 0 B8030000 10
Rate table has 300 entries (16 legacy/64 11n/220 11ac)
POWER TABLE FILENAME = ram:/D2.bin
Radio1 present 8364B 8000 B0020000 0 B0030000 C
POWER TABLE FILENAME = ram:/D5.bin
This product contains cryptographic features and is subject to United
States and local country laws governing import, export, transfer and
use. Delivery of Cisco cryptographic products does not imply
third-party authority to import, export, distribute or use encryption.
Importers, exporters, distributors and users are responsible for
compliance with U.S. and local country laws. By using this product you
agree to comply with applicable laws and regulations. If you are unable
to comply with U.S. and local laws, return this product immediately.
A summary of U.S. laws governing Cisco cryptographic products may be found at:
http://www.cisco.com/wwl/export/crypto/tool/stqrg.html
If you require further assistance please contact us by sending email to
export@cisco.com.
cisco AIR-CAP3502E-A-K9 (PowerPC460exr) processor (revision A0) with 98294K/32768K bytes of memory.
Processor board ID FTX1627K3N9
PowerPC460exr CPU at 666MHz, revision number 0x18A8
Last reset from power-on
LWAPP image version 7.6.130.16
1 Gigabit Ethernet interface
2 802.11 Radios
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: D8:67:D9:9D:06:C7
Part Number : 73-12175-06
PCA Assembly Number : 800-32268-06
PCA Revision Number : A0
PCB Serial Number : FOC162230CJ
Top Assembly Part Number : 800-32904-02
Top Assembly Serial Number : FTX1627K3N9
Top Revision Number : A0
Product/Model Number : AIR-CAP3502E-A-K9
% Please define a domain-name first.
Press RETURN to get started!
*Mar 1 00:00:10.865: %SOAP_FIPS-2-SELF_TEST_IOS_SUCCESS: IOS crypto FIPS self test passed (11)
*Mar 1 00:00:10.868: *** CRASH_LOG = YES
*Mar 1 00:00:10.868: 64bit PCIE devices
*Mar 1 00:00:11.975: %SOAP_FIPS-2-SELF_TEST_HW_SUCCESS: HW crypto FIPS self test passed (1-4)
*Mar 1 00:00:11.975: Security Core found.
*Mar 1 00:00:11.988: Registering HW DTLS
Base Ethernet MAC address: D8:67:D9:9D:06:C7
*Mar 1 00:00:53.040: %LINK-6-UPDOWN: Interface GigabitEthernet0, changed state to up
*Mar 1 00:00:56.129: %SOAP_FIPS-2-SELF_TEST_RAD_SUCCESS: RADIO crypto FIPS self test passed on interface Dot11Radio 0 (4)
*Mar 1 00:00:59.397: %SOAP_FIPS-2-SELF_TEST_RAD_SUCCESS: RADIO crypto FIPS self test passed on interface Dot11Radio 1 (4)capwap_read_version_info: Info file flash:/ap3g1-k9w8-mx.ap_lmr1_v15t_esc.201309060723/info not find
*Mar 1 00:13:24.185: %SYS-5-RESTART: System restarted --
*Mar 1 00:13:24.185: %SNMP-5-COLDSTART: SNMP agent on host APd867.d99d.06c7 is undergoing a cold start
*Mar 1 00:13:24.226: %CDP_PD-4-POWER_OK: Full power - AC_ADAPTOR inline power source
*Mar 1 00:13:24.267: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to up
*Mar 1 00:13:24.434: %SSH-5-ENABLED: SSH 2.0 has been enabled
*Mar 1 00:13:24.434: %LINK-6-UPDOWN: Interface Dot11Radio1, changed state to uplwapp_crypto_init: MIC Present and Parsed Successfully
*Mar 1 00:13:25.226: %LINEPROTO-5-UPDOWN: Line protocol on Interface BVI1, changed state to up%Default route without gateway, if not a point-to-point interface, may impact performance
*Mar 1 00:13:42.717: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to reset
*Mar 1 00:13:43.805: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to up
*Mar 1 00:13:43.811: %LINK-5-CHANGED: Interface Dot11Radio1, changed state to reset
*Mar 1 00:13:44.805: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to up
*Mar 1 00:13:44.903: %LINK-6-UPDOWN: Interface Dot11Radio1, changed state to up
*Mar 1 00:13:45.903: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio1, changed state to up
*Mar 1 00:13:52.714: Logging LWAPP message to 255.255.255.255.
*Mar 1 00:13:54.702: %LINK-6-UPDOWN: Interface BVI1, changed state to down
*Mar 1 00:13:55.702: %LINEPROTO-5-UPDOWN: Line protocol on Interface BVI1, changed state to down
