JoJo_ReloadeD
- Joined
- May 12, 2007
- Messages
- 120
Hi all!
Lately I'm having problems with my model 80. It had the 162/163 errors due to a expired battery. I ordered a CR123 to replace it and installed today. All without troubles... or that was I was thinking...
First of all the text (80x25 mode) is in black and white... and it didn't start windows 95. Screen flickered when loading the desktop and then the system hanged and started beeping. It must be the XGA2, checked it and seemed ok. I went to check the memory and checkit also hanged. Doom worked flawlessly. Tried memtest (a version that works on 386 systems). Hangs too...
It must be the CPU I thought, I have it with a Cyrix 486drx2@50 (I have the 25mhz board). Uninstalled the CPU and saw it has a bent pin. I repaired it and installed it again... same errors.
Well, I must have fried the CPU, swapped it with another Cyrix, same result... tried its standard 386@25... same result...
It must be the add on cards... tried to unplug all of them and I got the same error. Also with the onboard vga I am getting the black and white text instead the color one... even on the menus of the reference disk...
I'm out of ideas right now...
