P pearce_jj Veteran Member Joined May 14, 2010 Messages 2,808 Location UK Dec 29, 2011 #21 Be very careful about the power requirements, as most of the 1000's had PSUs with very low output. Sounds like an XT/IDE is the answer on this one - might be worth a post in the wanted section.
vwestlife Veteran Member Joined May 2, 2008 Messages 5,405 Location central NJ Dec 29, 2011 #22 pearce_jj said: Be very careful about the power requirements, as most of the 1000's had PSUs with very low output. Click to expand... The 1000SX's power supply is rated at 67 watts. My original 1000 has no trouble with an ST-225 and all three ISA slots filled.
P pearce_jj Veteran Member Joined May 14, 2010 Messages 2,808 Location UK Dec 29, 2011 #23 I have a similar setup in a 5150 with an ST-251. Sitting idle at DOS prompt it draws 102W at the wall...., so very close to, if not touching it's rated output (63W in that case).
