gatewayrepairs1985
Hi all,
I am currently trying to configure an Ultrastor 24F SCSI EISA card in my Anigma motherboard EISA system. I have the EISA .CFG file and I successfully loaded it using an EISA configuration utility, however no matter what I do/change I get an error message on startup - "Disk Controller RAM Error at 3E00." I looked it up and the manual says to change the BIOS address in the EISA configuration utility if this error occurs. Well, I changed the BIOS address to all available options in the EISA configuration utility and I get the same error every time. Only when I disable the BIOS address in the EISA configuration utility does the RAM error go away; but then the card still doesn't work. I'm currently at a loss and could really use some help to get this card up and running. Any advice would be greatly appreciated, thanks!
