Adventurer
Bought this machine on Ebay for needs for connecting older drivers/using other floppy formats.
Specs:
286/16 - 1MB RAM
52MB HDD
Was listed as "Hard drive not working, both floppies read fine". Due to careless packaging it arrived in the following condition:
* Hard drive still not working, HDD controler failure on boot (would be a surprise, would not it?)
* 3.5 floppy drive dead, with only some faint signs of life, does not read/write anything
* 5.25 floppy drive dead, can not read/write/format
* Backup battery has been removed, but the signs of corrosion are still there.
* Unstable when switched on, sometimes loosing extended memory (384K)
Had no other choice, but to disassemble the machine completely in order to solve the problems...
Then:
* 3.25 inch floppy drive was replaced
* Hard drive - in fact, was alive, but the problem was damaged power supply to "quick disconnect" cradle, no bad sectors, 52MB.
* A few caps replaced on the motherboard, one had been previously blown up - just melted legs remained there.
* Backup battery - connected fully charged 3.6 V Ni-MH battery pack to external backup battery connector- should keep settings for some time
* Cleaned, reassembled, DOS 5.0/Windows 3.1 installed.
* Test run - Indiana Jones Fate of Atlantis runs fine...
* Had some problems with serial ports, but sorted them out - I had made a mistake in cable polarity when connecting everything back
Specs:
286/16 - 1MB RAM
52MB HDD
Then:
