how to dump BIOS to a file?
mikey99
NC , USA
Is there a utility available to dump the BIOS of a PC or XT
to a file on diskette ? I have a couple of clone XT's that I'd
like to backup the BIOS just in case I ever need to reburn.
I imagine there might be a way to do this using DEBUG with the correct
address. Ideally it would be an image that was ready to burn
with an EEPROM burner in case the current BIOS chip died.
I would prefer not to pull the chips from the mb to copy.
Mbbrutman wrote a utility named 'PCjrcart', available at http://www.brutman.com/PCjr/pcjr_downloads.html
The DEBUG method:
If you know the address at which the BIOS starts and you know the BIOS size, you can suitably modify the following (saves 32K starting at F000 to file MYF000.BIN).
C:\> DEBUG
    -N MYF000.BIN          (resulting file will be named MYF000.BIN)
    -R BX                  (set BX=0000H/CX=8000H as count of bytes to write,  00008000H = 32K)
    BX 0000
    :0000
    -R CX
    CX 0000
    :8000
    -M F000:0 8000 0100    (copy 32K bytes from F000:0 to offset 0100 in local segment)
    -W 0100                (write from offset 0100 in local segment)
    Writing 8000 bytes
    -Q
Thanks - I didn't want to self promote. ;-)
Debug gives you a pure dump.. PCjrcart can do that too, but it can also scan the BIOS area for extensions. This is useful for dumping the BIOS on cards like SCSI adapters, VGA cards, etc.
Thanks for the info. I ran pcjrcart using the rom dump option
and it generated a 64KB file SYS_ROM.BIN. I edited the file
using a binary editor and there is header info like PCJRCART
date, time, filename ,etc.
If I had an EPROM burner, could I burn this file directly to
an EPROM, plug into my machine and it would work ?
Or would I be better off making a 'pure' dump using DEBUG?
Your ROM is probably not 64K. It is for a Jr, but on the PC and XT it is much smaller. (The PCjr has Diagnostics and other stuff in ROM.) You need to know the size of the ROM for your machine. There are options on pcjrcart for getting particular memory regions. You can do the same thing with debug, but it might be easier with pcjrcart.
I think that there is an option on PCjrcart to suppress the header .. you definitely don't want the header showing up.
If you run MSD (Microsoft Diagnostics), it will tell you what address region your system ROM occupies, and also for any option ROMs (video, hard drive controller, etc.) you have installed.
Generally if you dump more address space than your ROM actually occupies, the unused space will show up as a stream of 00 or FF hex.
C:\> DEBUG
    BX 0000
    :0000
    -R CX
    CX 0000
    :8000
    Writing 8000 bytes
    -Q
If you got a REALLY slow computer, you might change -M F000:0 8000 0100 to -M F000:0 7FFF 0100, saving you some nanoseconds :P
You can repeat the process with -N MYF800.BIN and -M F800:0 FFFF 0100 instead if you want the other half of the BIOS.
