vanderk
Hi! I've been brushing up on my MBASIC and developed some interesting programs. One is a hurricane tracking tool that provides a projected path storms/hurricanes on an ASCII map with a range of relevant data, save/load data, etc. It also afjusts the track based on the influence of nearby low/high pressure systems. I'd like to share the program and data files. What is a good place to post the files and code? A particular discussion board here or Github?
Maybe someone will have some fun with it!
Thanks!
80 PRINT "***************** HURRICANE TRACKER FOR THE KAYPRO COMPUTER ******************"
90 PRINT "WELCOME TO THE HURRICANE PATH PREDICTION TOOL FOR THE KAYPRO II COMPUTER."
100 PRINT "THIS TOOL CALCULATES A PROJECTED PATH OF HURRICANES AND VARIOUS RELATED DATA."
110 PRINT
120 PRINT "ESTIMATION METHOD: COMBINES LINEAR AND EXPONENTIAL WEIGHTING SCHEMES."
130 PRINT "PARAMETERS: DIRECTION, SPEED, COORDINATES (LAT-LONG), AND DIRECTIONAL CHANGES."
140 PRINT
150 PRINT "UNIQUE FEATURES:"
160 PRINT "- PREDICTIVE MODEL: USES A FORM OF TIME-DECAY WEIGHTING. FACTORS IN LINEARLY"
170 PRINT " WEIGHTED AVERAGE DIRECTION/SPEED & EXPONENTIALLY WEIGHTED DIRECTIONAL CHANGE."
180 PRINT "- VISUAL REPRESENTATION: PROJECTED (UP TO 5 DAYS) & HISTORIC PATHS ON MAP."
190 PRINT "- WIND SPEED CATEGORIES: CATEGORIZES HURRICANES BASED ON SUSTAINED WIND SPEEDS."
195 PRINT "- ADJUSTS PROJECTION BASED ON INFLUENCE OF NEARBY PRESSURE SYSTEMS."
200 PRINT "OPTIONS:"
210 PRINT "1. MANUAL ENTRY OF HURRICANE DATA (MAX 20 DAYS); DATA WILL BE SAVED TO STORM.DAT."
220 PRINT "2. LOAD FROM FILE (E.G., ELENA.DAT); SEE STORM.TXT FOR FILE LAYOUT.
230 PRINT "******************************************************************************"
Thanks!
110 PRINT
140 PRINT
