Hans01
I sometimes use the HxC SD adapter to setup a VHD.
I have a Model II with a VHD and I want to read a disk with TRSDOSII software on it from an image on the HxC, I can see that the disk is found and opened, but there are never files found on the disk.
Using TRSDOS2.0 there are no problems. If I have TRSDOSII running and try to read a TRSDOS2.0 with the FCOPY command, all the files on the disk are found.
I have put this problem on the HxC forum with an example, but Jeff told me there is nothing wrong.
I have a modified GOTEK with runs error free on the Model II, but has the same problem with the TRSDOSII disks.
Who knows this problem or has a solution.
I use the latest firmware on the HxC adapter and has the latest driver for the HxC emulator.
