VCF Southwest | Jun 20 - 22 2025, | University of Texas at Dallas |
VCF Southeast | Jun 20 - 22 2025, | Atlanta, GA |
<- info re: the BIOS bug...I remember reading somewhere that those ram banks just need to be "filled" but not necessarily with ram. Perhaps jumpering the banks to close the circuit can by pass the error code
I haven't tried this my self yet but could look into further.I have a sacrificial board to play with.
I once had a system with 256k and bad chips in every bank.Only Bank 0 which is 150ns... I still can't figure out what the other 3 banks have in them and google isn't producing any hits at all... Mystery chips!
All four RAM banks on the 5150 motherboard are permanently enabled. Therefore, you need to populate all four banks before adding a RAM card (which would be used to complement motherboard RAM). Note that, per [here], removing the RAM chips from a bank will not disable the bank.If it's a ram speed issue, I currently have the Lo-tech 1MB ram board in the system, but I'm using the ram on the motherboard vs. the ram on the card... I wonder if I can bypass the ram on the motherboard and if that helps at all... hmmmmm
