Cyberstein
- Joined
- Dec 26, 2021
- Messages
- 76
I recently purchased 2 IBM PC Convertible printers. One came with an IBM 5140 PC Convertible I purchased and the other was NOS from TexElec. I knew the one I bought with the PC was damaged as they stated so in the listing. It's paper release was broke, which I was able to repair. When I tested though, It skips every other line I print. I then tested the NOS one from TexElec. It was worse, it would not move it's print head. I opened it up and found mechanical damage in two places, which I was also able to repair. I then tested it and to my surprise, it also is skipping every other line. That being said, I have two printers doing exactly the same thing. Other than skipping every other line, they both work perfectly otherwise. Has anybody else ran into this issue? It must be common if I have two of them doing the same thing. It does this when I print screen, print from DOS Edit, and even from the print diagnostics. If anybody has any insight into this, let me know. I did find someone stating this issue on Reddit, but I am not convinced of their finding/solution. If I find the issue, I'll post it. Thanks!
