I guess I need to start working on this before I try to power it on. This is the board:
It has a problem in the power input area and some tantalum capacitors are disconnected. If any of you experts can spot anything else, I'm all ears. Now, pretty lol question, but are the 2 missing pins in the power area really "ripped off", or does this board normally have them like this? (I've seen at least one more such board with these 2 pins missing). Then, with the tantalums, I wonder what I can replace these with. The one on the top right that has one leg disconnected is labeled : 106 +16K
To test this board, I'll also have to wait for my CGA/EGA --> VGA signal converter card to arrive, as I lack a pre-VGA monitor, I also lack an 8-bit I/O controller, but I do have an EGA video card. Final question, for now, is if I can use a typical 1.44 or 1.2 floppy with this board. I know it doesn't support HD, but will it at least accept the drives in DD mode, or will only real 720 and 360K drives work?
