Skip94
Hi all
I was getting one of my spare 5150's ready to move onto a new home when it failed
It was in the middle of booting, when it died to a black screen. Next power up, it sat on the blinking cursor for 5-10 minutes before I got bored and killed the power. Every subsequent power up, it shows no sign of life and produces a continuous tone from the PC speaker.
I have pulled the last 3 banks of RAM and the ROMs, no change. Pulled the CPU, no change. Only thing that stops the tone is pulling the 8284 clock generator, but I guess thats to be expected.
It seems the continuous tone is not a very common issue with the 5150 board, but reading through the 3 examples on -0degrees has so far not brought me any joy.
I did see U13, LS245 mentioned, so scoped that, all looks fine. I also checked U14 while I was there and found an issue, one of the outputs was held high all the time. Swapped it out for a good LS245 and the output is now behaving as expected, however, no change to the motherboard behaviour.
I'm now at a bit of a loss, but would like to try and diagnose the issue before hitting it with the parts cannon.
Any thoughts would be appreciated
Cheers
Andrew
Cheers
Andrew
