Isn't it good for independent loading as well, i.e. unit contains load resistors ?I have not seen that tester before but the one i have for ATX PSU's is nothing more than a glorified DMM, eg: It shows all the output voltages and PG on one screen, It's handy for that but nowt else.
POWER GOOD is a TTL level signal, not a supply voltage. And so expected is a voltage at roughly +5V.I tested all connectors with the following results:
It is important that the PSU be adequately loaded, otherwise a lot of PSU's of this vintage will shut down.So now P10 orange is looking good. Not sure what happened. I did two test that with both at .45V.
When I got the .45 V on the p10 connector the drive was connected.Isn't it good for independent loading as well, i.e. unit contains load resistors ?
So maybe when you saw 0.45V, you had the hard drive disconnected at the time ?
The circuit diagram of the receiver card shows that it uses +5V only. Earlier, it appeared that your PSU was not producing +5V, but you have subsequently found that +5V is being produced, and on P9. So, at this point, the low +12V voltage on the P10 connector is a distraction to finding the cause of the 1801 error.I re-connected the fan closed up PSU, plugged in all connectors (2 to the Motherboard and 1 to the drive / P10 was for additional drive that was not installed). Re-tested the orange wire on P10. The results were +63.2mV. I think this is way low.
It does load the PSU yes, But not enough,, I have deliberately connected up known faulty PSU's and at first look all appears good on screen until more loads added, Even then depending on the fault the on screen readings may not change. I certainly don't trust it, It's just a glorified DMM to me.Isn't it good for independent loading as well, i.e. unit contains load resistors ?
A faulty 12v DC fan could drag down the voltage rail, Am i right in thinking when you had the PSU on the bench you used the Hard drive etc from the 5161 expansion unit as loads ??, It's best to use known good working loads, One of those loads you used could be faulty ?. Of course the PSU may be faulty but prove it is or is not first on the bench.I had removed the FAN. Could the FAN be bad?
Thank you for the suggestion. I did try to remove each connector (thus removing each potential bad load) and retested. I continued to get bad reading on all tests. So I don't think my problem is a bad load.A faulty 12v DC fan could drag down the voltage rail, Am i right in thinking when you had the PSU on the bench you used the Hard drive etc from the 5161 expansion unit as loads ??, It's best to use known good working loads, One of those loads you used could be faulty ?. Of course the PSU may be faulty but prove it is or is not first on the bench.
The tests done in post #20 were done with no load, the PSU open, and the fan removed. Next, I plan on re-opening the PSU and testing with the fan hooked up. I'll also do some tests with with various loads.In post #20, all voltage measurements were as expected (except for POWER GOOD, way exceeding the expected +5V, roughly).
So what has changed between post #20 and now !
That is actually +12.38V.This time it tested bad -12.38 and -.447v on the p10 connector.
Good catch Thank you. I must have check the leads three or 4 times, but, never checked the plugs into the DMM. I feel like a big dummy. You given me hope. I'll retest and provide an update later in the day.That is actually +12.38V.
Why?
The red and black wires cables are connected to the wrong sockets on the meter.
Remember to keep an open mind. There could be multiple problems. For example:You given me hope. I'll retest and provide an update later in the day.
What is the Power Good reading now ?, With nothing connected to the PSU, Previously it was way too high,I'm thinking the PSU is OK and the problem is related to the expansion unit's mother board.
And with just the hard drive plugged in ? and does it spin up fully13.6 mV
