modernclassic
- Joined
- May 31, 2018
- Messages
- 14
I just bought a CT2910 Sound Blaster 16 for my 5150, mainly for the joystick port but figured I'd have fun poking around with the few SB-compatible games I could run on it too. This is a 16 bit ISA card but does normally work in 8 bit slots based on posts I've read from others here. I've checked and double checked all the jumper settings.
When I turn on my PC, the card audibly "clicks" and then I either get immediate continuous long beeps from the PC, or I get nothing for 30 seconds or so (not even blinking cursor), then the same continuous beeps. I've checked the POST error codes and there's nothing about continuous long beeps. When the beeps start, whether immediately or after 30 seconds, I hear the card click again simultaneously.
If I take the card out, the PC boots fine.
Does this sound like anything obvious? I mean, more specific than "sounds like the problem's the sound card!" I thought maybe an IRQ conflict with the IDE controller that can't be disabled, but I tried setting the jumper for IRQ 10 through 15 and no setting made any difference.
Thanks...
Thanks...
