kingchops
I managed to get my hands on an IBM 5151 monochrome display. Was the usual ebay purchase and it was untested so I didn't know if it even worked. But gladly when I configured my video card to output in monochrome mode I got it working. Seems to work ok but I'm having some issues getting the ideal video mode. When I fire the pc up (5150), the display mode takes up most of the screen but to the very right on the screen the picture is compressed. At first I though this was a geometry issue but after futher experimentation, I found that I could get an even picture by changing the mode to 80 columns using the dos "mode 80" command. When I run it in this mode the screen geometry is good but it doesn't take up the full area of the screen. I even managed to get Windows 2.0 running in monochrome mode and it looks ok, but same issue with taking up a reduced area of the screen. See pics below.
I suspect it's related to the monochrome mode being output by my display adapter, a Video7 VEGA (VGA/EGA).
It's a little hard to see in the photo, but if you look at the very right of the picture you'll see that the picture is squashed:
Here it is in 80 column mode, geometry is ok but there's a wide border around the graphic area:
