I'm the guy who's card TheMaritimeMan was talking about, the cap that was dodgy was C19 (it's top had cracked open), I swapped it with C8 which was the same type and looked ok visually (So now C8 was in C19's position and C19 in C8's), the moment I powered on the computer, the suspected bad cap that I'd put in C8's place exploded instantly (I've never turned a computer off faster than when that happened. lol). So I knew for sure now that that cap was bad, so I replaced it with a junkbox spare and hoped for the best. When I powered up the computer again, the card was working pefectly, and I did leave the system running for quite awhile, to see if the intermittent character fault would return, it did not, and what's more, is that CGA graphics mode was now working perfect as well (Before replacing the cap, if I put the card into 320x200 graphics mode, the screen would flicker and go blank at random). So all in all, I'd say capacitors can definitely cause this problem.
