themaritimegirl
I'm having a heck of a time trying to get a TSR mouse driver to work right on my IBM 5155, running MS-DOS 5. I have a 90's Microsoft serial mouse plugged into the serial port of an AST SixPackPlus card. It's the only serial port in the system, and so the card is configured as such - COM1 and IRQ4.
Windows 3.0 detects and works with the mouse with no issues. But I'm having problems getting other software, which relies on a TSR driver, to work. The two programs I'm testing with are EDIT and DOSSHELL. I've tried three different mouse drivers - MOUSE.COM, CTMOUSE 1.9.1, and CTMOUSE 2.1b4.
With MOUSE.COM, EDIT works just fine. When I attempt to run DOSSHELL however, it just switches the video to 40-column mode and immediately goes back to the C:\ prompt, with no message. Any attempt to run DOSSHELL thereafter results in the message "Unable to load MS-DOS Shell".
With CTMOUSE 1.9.1, DOSSHELL works just fine, but when I start EDIT, it does start, but there is no video. If I crank the CRT brightness up, I can see flickering, with no intelligible video. I can exit EDIT, but there remains no video - I have to reboot to solve it. Oddly enough, however, If I run DOSSHELL first, exit, and then run EDIT, EDIT appears and works just fine, mouse and all.
When I try to run CTMOUSE 2.1b4, it successfully finds the mouse, and then reports "Divide overflow". It then steals all of the system memory, and I have to reboot.
Anyone know what might be going on here? Again, Windows 3.0 works just fine with the mouse, out-of-box, and I've also tested it with MOUSE.COM running, and it still works just fine.
