IBM 5162 Weird CPU reset
Maybe your procedure is correct and we're still after the root cause of the problem. Though, now that I know the boot process a little better, I don't understand why just grounding I/O CH RDY would stop the CPU starting to execute the ROM code on a 5162 since it would still get a ready signal via /SRDY when accessing the ROM (for 0xFE0000-0xFFFFFF, WAIT0 is high) (on a 5170, the /SRDY signal is just tied high).
In the datasheet for the 82284 is:
My translation of that (written in a way that I prefer) is:
/READY is LOW when either of the following conditions is true:
Cond #1: [/ARDYEN plus /ARDY are both LOW]
Cond #2 [/SRDYEN plus /SRDY are both LOW]
Which means that for /READY to be HIGH (what we want for the 'ground I/O CH RDY' procedure), both of the following conditions need to be true:
Cond #1: [/ARDYEN is HIGH] or [/ARDY is HIGH]
Cond #2: [/SRDYEN is HIGH] or [/SRDY is HIGH]
In the 'ground I/O CH RDY' procedure, /ARDYEN and /SRDYEN are LOW. Which means that both /ARDY and /SRDY will need to be HIGH.
It fits with your experiment of, "I tested tying DWAIT0 to ground with a 25ohms resistor (pin 18 on U14) and now the CPU behave has expected on reset with the ground I/O CH RDY procedure." That would have resulted in /SRDY being HIGH.
(As you stated before, on the IBM 5170, the /SRDY pin is tied high via a resistor.)
Does that all sound right ?
Yes, exactly!
In the 5162, /ARDYEN and /SRDYEN are connected together to the -ARDYEN signal witch comes from a /Q output of a flip-flop, the D input of said flip-flop is tied to the "DATA CONV" signal from U27 (some sort of glue logic chip/rom ?).
I don't know if this is normal, but my -ARDYEN signal was always low when testing, so the CPU would get a low /READY signal as soon as either /ARDY or /SRDY is low (well with different timing sync but that's not relevant here I think)
In the meantime, I recompiled minipro adding a sleep function just before the read of the bipolar PROM and now I get the same file each and every time so this dump should not be corrupted :)
I completely agree! Now I have to understand why the other 5162 tested with this procedure didn't need the DWAIT0 signal tied to ground to stop executing the BIOS code on boot... :unsure:
I completely agree!
I brought out an IBM 5170 motherboard. As expected, grounding the 'I/O CH RDY' line resulted in the 82284's /ARDY pin being taken HIGH.
In the IBM 5170, the 82244's /SRDY pin is tied HIGH via a resistor.
So both /ARDY and /SRDY were HIGH.
As expected, I found the 82244's /READY pin at HIGH.
Experiment: I then grounded the 82244's /SRDY pin, and observed the 82244's /READY pin go LOW.
It certainly points to the requirement that for the 'ground I/O CH RDY' procedure, both /ARDY and /SRDY need to be HIGH.
Following are some possibilities that I can think of.
Possibility #1
- The 'ground I/O CH RDY' procedure, as it is written now, works.
- Your U90 ROM is faulty; for motherboard ROM addresses, it should be outputting a LOW to the WAIT0 line. (I.e. Motherboard 'system' ROMs gets a wait state.)
Possibility #2
- Your U90 is good.
- The 'ground I/O CH RDY' procedure, as it is written now, does not work; it should be doing something that results in /SRDY being taken HIGH.
- The person who indicated that the procedure works for them, has a 5162 motherboard that for unknown reason, has the 82244 outputting a HIGH on its /READY pin.
It would be good if another person, who has a known-good 5162 motherboard, try the 'ground I/O CH RDY' procedure for us.
Is there someone with an IBM 5162 (I do not have one) who is willing to do a test for us (me and the OP) ?
What we desire is for that person to start the 'ground I/O CH RDY' procedure' at [here], performing steps 1 and 2, and then seeing if the /SRDY pin (pin 2) of the 82284 chip is LOW or HIGH.
Diagram at [here].
/SRDY pin (pin 2) of the 82284 chip is HIGH.
Thank you very much.
Thanks a lot for your help.
Could you also check step 4 of the procedure ? Because my CPU sometimes stops after a few cycle, so if you have address 0xFFFFF0 on the ISA bus like [here] it would mean your CPU stopped on the first instruction (not like mine). :)
A12-A31: 00000000000001110000
C2-C8: 0000111
Checked on two working boards.
Not at all like what is expected.
Based on your 5162 thread at [here], you are using a multimeter to determine logic levels. To rule out a measurement issue, please confirm that your LOW's and HIGH's are being determined by the information at [here].
A thought too is that a multimeter may be very inappropriate for the 'ground I/O CH RDY' procedure' . There is an assumption that the initial part of the procedure will result in a 'steady' state, and therefore, a multimeter is okay to use. But what if, for whatever reason, the CPU is not in an endless wait - there is activity. A multimeter will not reveal that, giving misleading results. A logic probe would flash its pulse LED.
Even better I can see the correct data on the CPU data lines at this state. ("0x65EA" in my case because I'm using Supersoft BIOS on this test)
The above quote from post #8.
ALOIS54: Per above quote, in the 'ground I/O CH RDY' procedure, the 82284's /SRDY pin is found LOW, but if ALOIS54 does something that results in that pin being found HIGH at power-on time, the expected logic states are measured on the address pins of an ISA slot.
RASK: Two functional motherboards. In the 'ground I/O CH RDY' procedure, the 82284's /SRDY pin is found HIGH, but unexpected logic states are measured on the address pins of an ISA slot.
As I see it, there are two questions:
Q1. In the 'ground I/O CH RDY' procedure, why is the /SRDY pin found LOW for ALOIS54's motherboard, but found HIGH for RASK's motherboards?
- Due to a fault on ALOIS54's motherboard?
- Is it that some 5162 motherboards have different U90 ROM content (e.g. in some U90, motherboard ROM gets zero wait states, and in others, motherboard ROM gets one wait state) ?
Q2. RASK has functional motherboards. In the 'ground I/O CH RDY' procedure, why is RASK not seeing the expected logic states on the address pins of an ISA slot ?
I have a theory :
On the 5162 the /ARDY signal is used for RAM cards (0xA0000-0xDFFFF) and for I/O channel (0x100000-0xFDFFFF) and the /SRDY signal is for onboard RAM and ROM.
So grounding the I/O CH RDY signal would only stop the CPU when trying to access addresses associated to the /ARDY signal.
On my board, the CPU is executing a lot of ROM code (I'm using Supersoft BIOS) and resets frequently enough to (almost) always get a /SRDY signal
On RASK's boards, the CPU quickly execute the stock BIOS until it tries to access an address in the /ARDY range and stops at this stage because /ARDY will always stay high with this procedure.
I'm thinking of buying a logic analyzer to continue my troubleshoot, but models with enough bits (ie 32+) aren't cheap! :confused:
Just a quick update on my problem : I have finally bought a 32-bit 100Mhz logic analyzer (a Digilent Digital Discovery)
Using this nice instrument I have discovered a first fault : bits 11 and 15 on the data bus (D) were disconnected between the CPU and U100.
After a bit of soldering, now the board starts beeping every single time I'm booting it with the SuperSoft ROM but it still resets/crash after a few seconds... :cry:
So I think I had 2 different problems, a bad connection on the D bus (when the board didn't boot at all) and a corruption/timing/read error problem leading to resets and crashes. I don't think theses 2 problems were related...
I must now find why I have this reset/crash problem, I'm pretty sure this is ROM read errors (because at this stage, the SuperSoft BIOS isn't using any RAM and is just executing ROM code).
I've bough a few Winbond W27E257-12 to help me with this debug, I burned a pair with just a jump to the start of the ROM and completely filled the rest with noop (0x90)
I have to study timings of the 80286 and I might have to buy small probes since this might be a timing problem, I can't simply use the ISA Bus for the address lines... :unsure:
