Hello everyone,
I saw what was done in these designs, where you want to preserve the original DRAM memory control, which is one possible functional route to go.
At least, I am only going from what I could see in the PDF circuit diagram of Mans only.
This is definately the least invasive method of course, it all depends on what the plan is of course and what someone would be willing to modify which will differ.
I see that Sponaugle is using a different method to make his own decoders which is definately also minimally invasive which is appealing in its own way.
This thread caught my interest because I am currently working on a NCR PC-8 rev 0 which is basically a clone of the IBM 5170.
I got the PCB from Ebay without CPU, ROMs, CMOS clock and keyboard controller. (I hate it when they do that!)
And with only 256k of RAM on the PCB.
After a bit of work it's now working with a quadtel bios which is compatible with the IBM 5170.
I exchanged the PLCC CPU socket with a more modern one and used a Harris CS80286-16. and expanded to 640kb of DRAM.
I found that the mainboard only operates with the MC146818 and not with a DS12885, however it seems to work with a DS12887 so it is probably clock input related.
So far I ran a Norton NDIAGS comprehensive memory test without any errors so my DRAM appears to be Ok.
I can run DOS and windows 3.0 and tested patience for a while without crashes so the CPU is stable and so is the RAM and ISA bus.
So far so good, but then of course unfortunately there are some complications.
When I run any DMA operation, it disrupts the refresh or parity circuits which results in a parity check error and subsequent halting of the CPU.
I have also observed "internal stack overflow system halted" earlier as well.
Examples of where my mainboard crashes during DMA operations:
- floppy read/write access
- sound samples in WOLF3D game with Soundblaster Pro 2 - results in immediate freeze
The floppy drive is really an ideal DMA test for early discrete PCs such as these.
I have removed and tested the 8237 DMA controllers of the PC-8 mainboard in my XT, they are functional but the timing is not great.
I also found some sound glitches in WOLF3D but no actual crashes using these DMA controllers.
So I replaced both with better performing ones on the AT mainboard which worked well with floppy access and WOLF3D on my XT.
However this also didn't result in a stable DMA on the AT unfortunately.
My theory now is that the Harris CPU I used or something else in the system has different impedance from the original system which is throwing off the timing of the DMA control logic.
It's either that or something else is still defective. For example some of the programmable logic may have failed.
So I will need to remove and verify those too. This is a little tricky because I saw that the connection sequence is different from the IBM design.
I can't know because my mainboard was incomplete and not fully populated.
What I hope to achieve is to get a stable PC with this mainboard or a similar one which also can do DMA normally as originally designed.
This mainboard is of interest to me because I plan to design my own improved ATX version of this mainboard.
I did the same with the XT PC and integrated some useful interfaces into my PCB.
Anyone who likes to take a look can visit my website for reference.
Website van Knaap IC waarop u diverse relevante thema's en ideeën kunt vinden aangaande ICT voor bedrijven. U vindt op deze website een praktische kijk op kwesties en problemen die zich in de ICT van bedrijven kunnen voordoen. Knaap IC levert ICT hulp en diensten in regio achterhoek.
www.knaapic.nl
Just to get an idea of what I am aiming for in my next project with a discrete AT design.
What I intend to do is somewhat different from the designs featured in this thread, because I plan to do away with the existing CAS and RAS circuitry and memory management completely.
And I also plan to remove the parity checking circuits.
I will only connect the /DACK0 to the ISA bus for certain cards which use it as a timing reference.
Since I will be using SRAM only, there will be no need for all these circuits on my design.
Also, when I use adapter cards I will pay attention that there is no DRAM on them which depends on mainboard logic to refresh.
However I don't plan to use such cards. If there is more memory possible, I will enable this using SRAM instead and include the SRAM on the mainboard anyway.
I did the same changes on my XT design, however of course this time it will be a slightly more involved process since the IBM AT design is somewhat more complex.
However, if you view it from the other side, to simply cut out the unwanted circuits which were designed for DRAM anyway, and design from the specifications rather than from these original memory map circuits, the process may hopefully be more easy in my case for what I intend to do.
I may make some errors which I will need to correct later on if there are any things I may have overlooked in my design changes.
In theory, DMA should work fine with SRAM since it also does on my XT PC.
That's why I need this PC-8 as a reference, and that's the only reason I bought this mainboard.
These discrete chipset PCBs are rare to find so I was happy to find this PC-8.
However I was not impressed by the bad European PCB assembly quality since the PCB in my case has been soldered to the slot connectors in a warped fashion.
These DMA troubles are not something I expected, but it may be processor-specific and a sensitive aspect of this design, similar to what I found with DMA controllers in my XT design.
I expect that during my process I may find an ideal method of memory mapping.
Perhaps this method will be of use to others here who want to make an ISA card to plug into their PC.
Definately some not too invasive mods should be possible to disable the DRAM control and parity checking altogether.
This will definately make the IBM AT PC more stable and future proof in my opinion.
For those also interested in this route I can update my progress here in this forum.
However I first need to tackle this DMA trouble which is difficult.
I may try a different CPU also which is more close to the original one of this mainboard.
Only when I achieve 100% stability on a discrete AT PCB I can proceed with my project.
I don't want to risk finding unrecoverable problems further on since there is considerable work involved to design and build this project.
If there is anyone here who has some experience with DMA troubleshooting of the 5170, or even the NCR PC-8 rev 0, or who could be helpful to me in any other way, I would appreciate any help or advice of what you have tried.
I did replace the U64 74ALS573 with a 74HCT one which didn't give me any improvement, except to see higher output amplitude which looks better on a scope.
On my XT I did get some improvement by changing logic types of certain ICs, the DMA control remains a difficult thing but I tackled it finally on my XT.
Definately programmable logic is much faster than TTL logic equivalents.
If I am on a wrong track to find the solution for these parity problems I would also appreciate any advice.
So far it's still theoretical until I find the true solution anyway.
When I make progress in my project I will report it here, perhaps the theory of design can inspire similar other designs as discussed here as well.
If I can't get the DMA to work properly I may remove all the DRAM circuits and wire in my own version using SRAM.
That may be an alternative route to achieve a stable reference system.
I have only studied the IBM 5170 designs for a few days so far, not nearly as in-depth as my previous XT design yet.
Anyway, any ideas would be appreciated, I hope I can find someone who is familiar with what I am experiencing with the DMA here.
Kind regards,
Rodney
