floyd20183
Hello to all.
I have done some googling and still don't seem to find a definitive example of whether or not it is possible to connect a 9pin IBM CGA card to the RGB TTL DIN connector on the rear of the Phillips CM8833 monitor. I suspect that this may not be possible without additional circuitry but would be interested to hear if anyone else has actually tried and what the results were. In my search I have seen references to the the CM8833-II monitor but mine is the CM8833 with Scart and DIN RGB connector. I can use the composite out on the CGA card into the monitor but as mine is the PAL version the composite is only in black and white due to not being NTSC. The CM8833 doubles as my Amiga 500 monitor and it would be nice to have both machines on the same CRT. Any advice would be appreciated.
