Ozfer
Hey guys its me again and I need more help with my 5150.
Today I am tackling the issue with my add in ram card on my 5150. On the pc motherboard I have the full 256K of ram with all the slots fully populated and the system works fine with that and boots to dos. I also have what I believe to be a DiamondFlower MF-100 Ram card. This card I think holds 384k ram and would allow my 5150 to reach the max of 640k ram since all 6 banks are populated but I am having a heck of a time trying to get it to work.
If I boot the IBM with the ram card in and set to just 256k RAM it will boot up fine with the card inserted, also the joystick port on the card works. If I set the jumpers on the motherboard to reflect the 640k or anything else above 256k (82 model motherboard so I believe the jumpers are ON off ON ON off for 640k) I get 407E 201 and then PARITY CHECK 2. Parity check 2 I think refers to the expansion card and the error code should be telling me what part of the memory is bad but I don't know how to diagnose that.
I have no clue if the jumpers on the expansion card are good and I have tried re seating all the memory chips on the MF-100. Maybe some of the ram chips could be bad? As can be seen in the pics I uploaded the board is slightly bent due to age but it's not awful, and also the battery that was on the expansion board leaked a bit and I scraped most of that off. Would it need a functioning battery to work and could that be the issue?
The battery said Ni-CD 50Mah 3.6v can anyone confirm that this would work in its place?
Here are some details about the card I had a hard time understanding what it meant but I think they are the same card. As shown I switched the 6 pin block to what I believe to be the full amount but the switch block on the card doesn't say what position is on and off so I'm even unsure I have the card configured right. According to the jumper settings when I got the computer it was set to some weird amount of ram like 360K and I had no idea why. Please help I would upload more pics but I hit my limit already :S
http://www.angelfire.com/mn2/daveandkay/i/txt/54640.txt
http://www.angelfire.com/mn2/daveandkay/i/txt/52500.txt
http://www.ebay.com/itm/DIAMOND-FLO...NSION-CARD-NO-RAM-IBM-5150-5160-/300764702557
