TWAIN
Round Rock area. Not too far to meet up somewhere.Now that's cool. Where in Central Texas are you? I'm in Bandera county. A 4116 tester would be fantastic. My testers only do 4164 and 41256 sadly.
It may, though it’s a bit later with the sunken nut power supply. Hard to make out the serial number.I also found another IBM PC 5150 Rev.A (16-64KB).
IBM PC 5150 w/ Model F Keyboard & working Green Monochrome Display - For Repair | eBay
Find many great new & used options and get the best deals for IBM PC 5150 w/ Model F Keyboard & working Green Monochrome Display - For Repair at the best online prices at eBay! Free shipping for many products!www.ebay.com
It works and it may have Rev.0 BIOS (04/24/84, P/N:5700051)
It seems like a great price for a complete, early PC.
I thought the sunken nut PSU were on the first versions. My early one has a yellow label. I actually found someone selling a clone case/motherboard, but with the sunken nut IBM PSU and 2 black bracket cards (mono and floppy) for $75. I even told him, I didn't care about the other stuff - I just wanted the damn PSU for another Model A I'm trying to rebuild.It may, though it’s a bit later with the sunken nut power supply. Hard to make out the serial number.
The earliest ones were the raised nut version with the red label. I think they went to the black sunken nut version at about serial 160000-ish.I thought the sunken nut PSU were on the first versions. My early one has a yellow label. I actually found someone selling a clone case/motherboard, but with the sunken nut IBM PSU and 2 black bracket cards (mono and floppy) for $75. I even told him, I didn't care about the other stuff - I just wanted the damn PSU for another Model A I'm trying to rebuild.
In case you are unaware, see also the IBM 5150 section of minuszerodegrees.netThis thread has some great knowledge of the 5150.
Well, memory related. Quite a few possible causes - see PARITY CHECK 1 at [here].But apperantly it gives a : Parity check 1.
So a memory problem. Would it be hard to replace the module or parity module on the board?
Yes, after browsing I found a memory replacement procedure on this site.In case you are unaware, see also the IBM 5150 section of minuszerodegrees.net
Ah, I did not know about the soldered banks. I will think about this Ebay sale but will probablywait for a more working model.One or more faulty RAM chips on the motherboard is one of those possibilities. There may have been a 201 error (RAM error) flashing up on the screen before the PARITY CHECK 1. Sometimes, the RAM chips just need to be re-seated in their sockets. However, in the IBM 5150, the first bank of RAM chips are soldered to the motherboard, and so there is the possibility that some soldering is required.
