Hello all, after seeing the wonders of replacing hard drives with compact flash cards, I decided to try it for myself.
Recently, My lovely PC/AT had a hard drive crash, so this is the perfect time to try it out! I installed a brand new 16-bit IDE adapter with floppy controller and (from what I've seen) a good quality IDE-CF card adapter with a 4GB CF card. I set the BIOS hard drive type to 4, which will allow a ~62 MB partition to be formed. However, the problem I am having is getting the computer to boot with the adapter set to master. It gives a "107 System Board Failure" message with the card jumped to master, but boots normally when the card is configured as slave. In the latter configuration, I am able to partition and format the CF card, and even copy files to it, but I cannot run applications directly from the card. I can even see files that I have transferred from my modern machine on the card inside of DOS. The trouble must be originating with the slave configuration, but there is no way the computer will boot with the card set to master. I have also tried two other CF card adapters and four different CF cards, with the exact same result with any combination of adapter and drive.
Any suggestions on how to make this thing work?
