I'm troubleshooting an issue with an IBM PS/2 model 25 (8086 based) using Revision 0 system ROM (the ROM contains at the start 00F2122 (C) COPYRIGHT IBM CORPORATION 1981,1987 ALL RIGHTS RESERVED) with XTIDE Universal BIOS (XUB).
I can see previous threads where people get this machine working with the XUB but it doesn't want to initialise it at boot.
A known working card (in this case, XT-CF lite v2) can be programmed in the system OK and the XUB code can be read back from the card (after reboot) at the expected memory location. But, the XUB is not initialised at boot. Both standard and late initialisation have been tried.
It should be noted that the model 30 (286 based?) cannot be used with this card due to the hard-wired ZWS driver (ISA B8). However, I would presume that B8 is unconnected in the 8086 based Model 25?
