IBM System/23 Datamaster, display and character generation
I should have posted this a week ago, but I had no time to redo the schematic until today. I haven't retraced the parts in my board since last week so take this as a grain of salt.S23-video.png
The Datamaster has two clock sources for the CPU and three for the video subsystem. The latter can work at 18.432MHz or 18.2MHz if the European switch is set - the third source hasn't been identified yet. Two components receive the selected signal: the video shift register and a 74LS174 configured as a shift register, which samples an unidentified signal and feeds it to the 8275 as a clock.
The CRTC has two outputs to signal attributes and the s/23 uses them to select the value to the character ROM or another one generated by a 74LS139 and a couple of NOT gates. The result is fed to the video shift register and NANDed with something.
There is still a lot of work to do. I also feel something is wrong as the 139 also controls the select signal of the 157s...
