mkemp
My XT-286 has a 10mHz 80286 chip in it plus a patched BIOS without the 'speed bump' that should allow for clock speeds greater than 6mHz.
Has anyone tried this and, if so, what kind of speed could you achieve?
Note: the original power supply was dead and I didn't have a spare XT supply (ATs are too tall), so I transplanted the innards from a 230W ATX supply, did a bit of soldering to the Big Red Switch and used a ATX-to-AT cable. Works fine.
The other fun fact is that I found a Seagate ST31220A drive to run in it - 1.080gb that can be jumpered to act like two 540mb drives to get around OS limitations.
