Hi all,
I published on GitHub ( https://github.com/Laci1953/RC2014-CPM/tree/main/HiTech C compiler optimization ) an enhanced set of tools, replacing the original HiTech C toolchain.
The main goal of this project was to obtain an enhanced HiTech C compiler toolchain, to be used in two environments:
1 : generic, for all Z80 computers running CP/M 2.2
2 : specific, only for RC2014's provided with 128 KB RAM (SC108, SC114, SC118 or Phillip Stevens memory module) running CP/M 2.2
For the second (specific) environment, the basic idea was to use the upper 64KB RAM to extend the RAM space available for the HiTech tools.
This was done by intercepting (part of) the malloc/free calls used by a tool, by using some extra assembler code, to return pointers not from the "usual" lower 64KB RAM, but from the upper 64 KB RAM.
Practically, a new "memory allocator" was written, to handle the upper 64KB RAM space.
Of course, all the references to those pointers, in the C sources, must be handled by special routines, to move bytes from/to the upper 64KB RAM to the lower 64KB RAM.
Obviously, this means some extra code is executed, compared to the "original" HiTech tools, resulting in a longer execution time.
However, this loss of speed ( 10 to 15% ) is largely compensated by the big advantage obtained: to be able to compile larger C source files.
The results:
For the generic environment (all Z80 computers running CP/M 2.2) some limited improvements were obtained, mainly for P1 (4KB more RAM available)
For RC2014's provided with 128 KB RAM (SC108, SC114, SC118 or Phillip Stevens memory module) and 64MB CF,
some significant improvements were obtained, listed below:
- P1 (4KB more RAM available)
- CGEN (using the upper 64KB RAM for some of the malloc's)
- OPTIM (using the upper 64KB RAM for some of the malloc's)
The most significant improvement for this second environment (128KB RAM computers), is that OPTIM can handle now files that cannot be compiled on any available Z80 computer, including here also the emulators/simulators (Z80SIM, ZXCC).
For example, I was able to compile some of the CGEN files ONLY on my SC108 based RC2014.
Z80SIM and ZXCC failed to run OPTIM on those files ("no room"), while the enhanced OPTIM, executed on my SC108 based RC2014, finished the job without any problem.
Also, do not forget my Z80AS, a Z80 assembler compatible with the HiTech's ZAS ( see https://github.com/Laci1953/Z80AS ).
Z80AS must be added to this new toolset, to eliminate all the worries related to the size of files to be assembled.
As a conclusion, I consider this new HiTech tools as an improvement over the "classic" HiTech tools.
Mainly, the RC2014's provided with 128 KB RAM can now take full advantage of having more memory space, while working with the HiTech C tools.
Ladislau
The results:
Ladislau
