Hi all,
Sorry for all the Sun/Solaris related questions recently. I'm trying to get my Ultra 5 into a usable configuration and it's far more complex that I thought.
My latest problem is Solaris 8 - I want to install some packages to compile software from source. This includes things like gcc, automake etc.
After some searching around I found someone who has some precompiled Solaris packages for most things. Website is here and the files for Solaris 8 are here.
I downloaded gcc and installed it as per the instructions (decompressed the file, then ran pkgadd -d *filename*). This worked and it reported a successful installation at the end.
My problem then begins when I try to use gcc. Running a random ./configure comes up with 'gcc not found'. I then tried whereis gcc and got no results. I am assuming that the pkgadd SHOULD have put gcc into the path; but maybe it didn't. I don't want to manually put things into the path as I need to install 50+ packages this way; and that will take an eternity.
Have I done something obviously wrong? Does the system need a reboot after installing the package to update the PATH (only thing I haven't tried)?
This reminds me of early linux days. You'd try to install / compile something and spend weeks trying to sort out dependencies and random problems like this.... I'd like to avoid spending that much time!
