skate323k137
Hello all,
Recently I took the time to make a minor revision to Mike Willegal's brain board, doubling the onboard ROM space available by making use of the previously unused dip switch (Dip 2). This yields two main useful configs;
one - primary toggle switches between on board ROM and Apple 1 emulation (Wozaniam mode)
two - DIP2 toggles between INTEGER and APPLESOFT BASIC (See link at end of post).
Mike used to sell these kits for his original design (when he still did, he does not anymore). The last run was sold for $59/kit and I believe I can make that same price a reality with even 5-10 commitments. PCBs are already in hand as are 95% of the parts to make several kits. I am using black finish ENIG PCBs with a beveled edge connector, not cheap HASL boards.
Here is a picture of a completed board, socket style may vary.
If you are interested let me know, if we get at least 5 people I will probably call it good and start dividing up kits. Much more information on this revision to the board can be found here:
Cheers,
Alex
Reviving Mike Willegal's 'Brain Board' For Apple II computers
UPDATE: I was able to add a pull up resistor to the PCB, which along with some other quick revisions enables manual use of DIP2 to toggle Integer or FP Applesoft Basic by toggling the highest address line of the 27C512. The ROM Code was provided by Macnoyd from AppleFritter, who has given...
68kmla.org
Cheers,
Alex
