I have an almost perfect tweener PC that I bough new back in '04. It came with a DVD RW and below that a 3.5 floppy. Also has 8 USB ports, 2 real serial ports, a parallel printer port and a multi card reader.
My main goal is to make various bootable 5¼ 360K DOS disks for my Tandy 1000EX. I just bought a Mitsumi D509V3 and installed an external toggle switch to choose between LD and HD. Works great, I can make DD 360K disks all day long that work perfect in the EX and with the flip of a switch I'm back to making HD 1.2mb disks.
The big downside to this PC is that the MB/BIOS only supports one floppy drive. I'd like to keep the 3.5 drive (I have P70s I like to move files to), but it'll be a pain going inside to move the cable each time I want to swap.
Would it be possible to keep both drives on the cable, but swap one or two wires using a SPDT or DPDT switch so that the system only recognizes one drive?
I'm thinking just switching the drive select would do it, or would I need more such as motor enable?
Thanks!
Thanks!
