Is there an RX01 Emulator?
Here is a snapshot of the latest RX02 emulator driver that finally passes the DEC diagnostics. Sometime this week I'll probably upload the entire project to github.
// rx02_driver - Simple :-) RX02 driver
// (C) 2013 Don North <ak6dn_at_mindspring_dot_com>
// 21 Oct 2013 - donorth - Initial code
// 27 Mar 2016 - donorth - Ported to Arduino from CCS/Microchip
// 23 Sep 2016 - donorth - Added clr_request to end of rx_xmit_es()
// 25 Sep 2016 - donorth - Reworked rx_init_es() to set status function dependent
// includes
#include "my_project.h"
#include "led_driver.h"
#include "rx02_driver.h"
#include "sdcard_driver.h"
// definitions
// options
#define USE_BIT_BUILTINS 0 // use bit builtins BitRead() etc vs use logical bit shift/mask operations
// RXCS control/status bit definitions
// definitions
// options
//efine RXCS_GO         (1<<0)      // GO bit                       (reference only; not used in drive)
#define RXCS_FUNCTION   (7<<1)      // function bitfield
#define RXCS_UNITSEL    (1<<4)      // unit select
//efine RXCS_DONE       (1<<5)      // function complete            (reference only; not used in drive)
//efine RXCS_INTENB     (1<<6)      // interrupt enable             (reference only; not used in drive)
//efine RXCS_8BIT       (1<<6)      // 8b mode                      (RX8E/RX28 ONLY)
//efine RXCS_TR         (1<<7)      // transfer request             (reference only; not used in drive)
//efine RXCS_MAINT      (1<<7)      // maintenance mode             (RX8E/RX28 ONLY)
#define RXCS_DENSEL     (1<<8)      // density select               (RX211/RX28 w/RX02 ONLY)
//efine RXCS_HEADSEL    (1<<9)      // head select                  (RX211/RX28 w/RX03 ONLY)
//efine RXCS_NU10      (1<<10)      // not used
//efine RXCS_RX02      (1<<11)      // RX02 interface               (reference only; not used in drive)
//efine RXCS_EXTADDR   (3<<12)      // upper bits of phys address   (reference only; not used in drive)
//efine RXCS_INIT      (1<<14)      // initialize RX                (reference only; not used in drive)
//efine RXCS_ERROR     (1<<15)      // error flag                   (reference only; not used in drive)
#define RXFCN_FILL        (0)       // fill buffer
#define RXFCN_EMPTY       (1)       // empty buffer
#define RXFCN_WRSECT      (2)       // write sector
#define RXFCN_RDSECT      (3)       // read sector
#define RXFCN_SETMEDIA    (4)       // set media density
#define RXFCN_RDSTAT      (5)       // read status
#define RXFCN_WRDDSECT    (6)       // write deleted data sector
#define RXFCN_RDERROR     (7)       // read error code
// RXES status bit definitions
//efine RXES_CRC        (1<<0)      // CRC aka READ error
//efine RXES_SIDRDY     (1<<1)      // side ready                   (RX211/RX28 ONLY)
//efine RXES_PERR       (1<<1)      // parity error                 (RX11/RX8E w/RX01 ONLY)
#define RXES_INIT       (1<<2)      // controller init done
#define RXES_RX02       (1<<3)      // set for RX02 drive           (RX28 w/ RX02 ONLY)
//efine RXES_ACLO       (1<<3)      // set for AC low               (RX211 w/RX02 ONLY)
//efine RXES_WPERR      (1<<3)      // set for write to WP drive    (RX11/RX8E w/RX01 ONLY)
#define RXES_DENERR     (1<<4)      // density error
#define RXES_DRVDEN     (1<<5)      // diskette double density
#define RXES_DELDATA    (1<<6)      // deleted data detected
#define RXES_DRVRDY     (1<<7)      // selected drive ready
#define RXES_UNITSEL    (1<<8)      // unit selected                (RX211 w/RX02 ONLY)
//efine RXES_HEADSEL    (1<<9)      // head selected                (RX211 w/RX03 ONLY
#define RXES_WCOVF     (1<<10)      // word count overflow          (RX211 w/RX02 ONLY)
//efine RXES_NXM       (1<<11)      // nonexistent memory           (RX211 w/RX02 reference only; not used in drive)
// RX error codes
#define RXERR_SUCCESS    0000       // success, no error
//efine RXERR_DR0INIT    0010       // drive 0 failed to init
//efine RXERR_DR1INIT    0020       // drive 1 failed to init
//efine RXERR_STEPHOME   0030       // found home when stepping for init (RX01 ONLY)
#define RXERR_TRKERR     0040       // access to track > 76
#define RXERR_TRKFAIL    0050       // track not found
//efine RXERR_SELFDIAG   0060       // self diagnostic fail (RX01 ONLY)
#define RXERR_SECFAIL    0070       // sector not found
//efine RXERR_WRITEWP    0100       // write to a WP drive (RX01 ONLY)
//efine RXERR_SEPFAIL    0110       // no SEP clock in 40us
//efine RXERR_PREFAIL    0120       // preamble not found
#define RXERR_IDMFAIL    0130       // ID mark not found
//efine RXERR_CRCHEAD    0140       // CRC error on a header (RX01 ONLY)
//efine RXERR_TRKCMP     0150       // header track miscompare
//efine RXERR_IDMTRYS    0160       // too many tries for IDAM
//efine RXERR_DAMFAIL    0170       // data AM not found
//efine RXERR_CRCERR     0200       // CRC error on read
//efine RXERR_PERR       0210       // parity error on word from i/f to controller (RX01 ONLY)
//efine RXERR_RWFAIL     0220       // r/w failed maint test (RX02 ONLY)
#define RXERR_WCOVF      0230       // word count overflow (RX02 ONLY)
#define RXERR_DENERR     0240       // density error (RX02 ONLY)
#define RXERR_KEYERR     0250       // wrong key word for set density (RX02 ONLY)
// macros
// rx interface outputs set/clr
#if USE_BIT_BUILTINS
#define rx_set_done(xxx)     bitSet(PORTA,6)    /* digitalWrite(PIN_CTLR_DONE_H,HIGH) */
#define rx_clr_done(xxx)     bitClear(PORTA,6)  /* digitalWrite(PIN_CTLR_DONE_H,LOW) */
#define rx_set_error(xxx)    bitSet(PORTA,7)    /* digitalWrite(PIN_CTLR_ERROR_H,HIGH) */
#define rx_clr_error(xxx)    bitClear(PORTA,7)  /* digitalWrite(PIN_CTLR_ERROR_H,LOW) */
#define rx_set_aclo(xxx)     bitSet(PORTC,1)    /* digitalWrite(PIN_CTLR_ACLO_H,HIGH) */
#define rx_clr_aclo(xxx)     bitClear(PORTC,1)  /* digitalWrite(PIN_CTLR_ACLO_H,LOW) */
#define rx_set_shift(xxx)    bitSet(PORTC,2)    /* digitalWrite(PIN_CTLR_SHIFT_H,HIGH) */
#define rx_clr_shift(xxx)    bitClear(PORTC,2)  /* digitalWrite(PIN_CTLR_SHIFT_H,LOW) */
#define rx_set_out(xxx)      bitSet(PORTC,3)    /* digitalWrite(PIN_CTLR_OUT_H,HIGH) */
#define rx_clr_out(xxx)      bitClear(PORTC,3)  /* digitalWrite(PIN_CTLR_OUT_H,LOW) */
#define rx_set_datao(xxx)    bitSet(PORTC,5)    /* digitalWrite(PIN_CTLR_DATAO_H,HIGH) */
#define rx_clr_datao(xxx)    bitClear(PORTC,5)  /* digitalWrite(PIN_CTLR_DATAO_H,LOW) */
#define rx_set_request(xxx)  bitSet(PORTC,6)    /* digitalWrite(PIN_CTLR_TR_RQST_H,HIGH) */
#define rx_clr_request(xxx)  bitClear(PORTC,6)  /* digitalWrite(PIN_CTLR_TR_RQST_H,LOW) */
// rx interface inputs test
#define rx_tst_pio(xxx)      bitRead(PINC,0)    /*  digitalRead(PIN_CTLR_DMA_MODE_L) */
#define rx_tst_dma(xxx)      (rx_tst_pio()?0:1) /* !digitalRead(PIN_CTLR_DMA_MODE_L) */
#define rx_tst_datai(xxx)    bitRead(PINC,4)    /*  digitalRead(PIN_CTLR_DATAI_H) */
#define rx_tst_12b(xxx)      bitRead(PINC,7)    /*  digitalRead(PIN_CTLR_12BIT_H) */
#define rx_tst_8b(xxx)       (rx_tst_12b()?0:1) /* !digitalRead(PIN_CTLR_12BIT_H) */
#define rx_tst_run(xxx)      bitRead(PINE,4)    /*  digitalRead(PIN_CTLR_RUN_H)) */
#define rx_tst_init(xxx)     bitRead(PINE,5)    /*  digitalRead(PIN_CTLR_INIT_H) */
#else
#define rx_set_done(xxx)     PORTA |=  (1<<6)  /* digitalWrite(PIN_CTLR_DONE_H,HIGH) */
#define rx_clr_done(xxx)     PORTA &= ~(1<<6)  /* digitalWrite(PIN_CTLR_DONE_H,LOW) */
#define rx_set_error(xxx)    PORTA |=  (1<<7)  /* digitalWrite(PIN_CTLR_ERROR_H,HIGH) */
#define rx_clr_error(xxx)    PORTA &= ~(1<<7)  /* digitalWrite(PIN_CTLR_ERROR_H,LOW) */
#define rx_set_aclo(xxx)     PORTC |=  (1<<1)  /* digitalWrite(PIN_CTLR_ACLO_H,HIGH) */
#define rx_clr_aclo(xxx)     PORTC &= ~(1<<1)  /* digitalWrite(PIN_CTLR_ACLO_H,LOW) */
#define rx_set_shift(xxx)    PORTC |=  (1<<2)  /* digitalWrite(PIN_CTLR_SHIFT_H,HIGH) */
#define rx_clr_shift(xxx)    PORTC &= ~(1<<2)  /* digitalWrite(PIN_CTLR_SHIFT_H,LOW) */
#define rx_set_out(xxx)      PORTC |=  (1<<3)  /* digitalWrite(PIN_CTLR_OUT_H,HIGH) */
#define rx_clr_out(xxx)      PORTC &= ~(1<<3)  /* digitalWrite(PIN_CTLR_OUT_H,LOW) */
#define rx_set_datao(xxx)    PORTC |=  (1<<5)  /* digitalWrite(PIN_CTLR_DATAO_H,HIGH) */
#define rx_clr_datao(xxx)    PORTC &= ~(1<<5)  /* digitalWrite(PIN_CTLR_DATAO_H,LOW) */
#define rx_set_request(xxx)  PORTC |=  (1<<6)  /* digitalWrite(PIN_CTLR_TR_RQST_H,HIGH) */
#define rx_clr_request(xxx)  PORTC &= ~(1<<6)  /* digitalWrite(PIN_CTLR_TR_RQST_H,LOW) */
#define rx_tst_pio(xxx)     ((PINC & (1<<0)) ? 1 : 0) /* (digitalRead(PIN_CTLR_DMA_MODE_L)==HIGH) */
#define rx_tst_dma(xxx)     ((PINC & (1<<0)) ? 0 : 1) /* (digitalRead(PIN_CTLR_DMA_MODE_L)==LOW) */
#define rx_tst_datai(xxx)   ((PINC & (1<<4)) ? 1 : 0) /* digitalRead(PIN_CTLR_DATAI_H) */
#define rx_tst_12b(xxx)     ((PINC & (1<<7)) ? 1 : 0) /* (digitalRead(PIN_CTLR_12BIT_H)==HIGH) */
#define rx_tst_8b(xxx)      ((PINC & (1<<7)) ? 0 : 1) /* (digitalRead(PIN_CTLR_12BIT_H)==LOW) */
#define rx_tst_run(xxx)     ((PINE & (1<<4)) ? 1 : 0) /* (digitalRead(PIN_CTLR_RUN_H)==HIGH) */
#define rx_tst_init(xxx)    ((PINE & (1<<5)) ? 1 : 0) /* (digitalRead(PIN_CTLR_INIT_H)==HIGH) */
#endif
// INIT/RUN status
#define RX_SAW_NONE     0               // saw neither RUN or INIT
#define RX_SAW_RUN      1               // saw RUN and not INIT
// emulation type
#define RX_TYPE_NONE    0               // no type defined
#define RX_TYPE_RX01	1               // RX02 in RX01 mode
#define RX_TYPE_RX02    2               // RX02 in native mode
#define RX_TYPE_RX03    3               // RX02 in dual-sided RX03 mode (***UNSUPPORTED***)
// drive density
#define RX_DEN_SD       0		        // single density mode (128B/sector)
#define RX_DEN_DD       1		        // double density mode (256B/sector)
#define RX_DEN_QD       2               //  quad  density mode (512B/sector) (***UNSUPPORTED***)
// data type
#define RX_DATA_NORMAL  0               // normal data
#define RX_DATA_DELETED 1               // deleted data
// timing characteristics
#define RX_TIME_INIT      0             // initialize floppy drive
#define RX_TIME_SEEK      1             // read/write seek time, position dependent
#define RX_TIME_RDSTAT    2             // read status function
#define RX_TIME_RDERROR   3             // read error registers
#define RX_TIME_SETMEDIA  4             // set media density
// disk definitions
#define RX_NTRKS        77L             // number of tracks per disk
#define RX_NSECS        26L             // number of sectors per track
#define RX_NBPS         128L            // bytes per sector, single density
#define RX_NUNITS       2               // number if units
// convenience macros
#define rx_sec_size(den)    (RX_NBPS<<(den))             // bytes per sector at density
#define rx_trk_size(den)    (RX_NSECS*rx_sec_size(den))  // bytes per track at density
#define rx_dsk_size(den)    (RX_NTRKS*rx_trk_size(den))  // bytes per disk at density
#define rx_get_bits(xxx)    (rx_tst_12b() ? 12 : 8)      // number of bits signaled by interface
// buffer sizes
#define RX_BUFFER_SIZE      (rx_sec_size(RX_DEN_DD))     // maximum size sector buffer for double density
// PRIVATE PRIVATE PRIVATE PRIVATE PRIVATE PRIVATE PRIVATE PRIVATE PRIVATE
volatile static uint8_t rx_run_seen; // set when RX RUN asserted (rising edge)
volatile static uint8_t rx_init_seen; // set when RX INIT asserted (rising edge)
static jmp_buf rx_init_env; // environment to invoke when INIT is asserted (ie, reset/error condition)
static char fcn_list[][8] = { "FILBUF", "EMPBUF", "WRSECT", "RDSECT", "SETMED", "RDSTAT", "WRDDSE", "RDERRC", "INIT" };
static char den_list[] = { 'S', 'D', 'Q' }; // Single, Double, Quad density flag
static uint8_t rx_type = RX_TYPE_RX02; // default drive emulation, can be overwritten
struct drv_t {
    uint32_t dd[RX_NTRKS];  // normal or deleted data per track per sector (1 bit per sector 0..31)
    char     name[32];      // associated file name
    uint8_t  rdy;           // drive ready
    uint8_t  den;           // density
    uint8_t  ta;		    // track address
    uint8_t  sa;            // sector address
    uint16_t len;           // read/write length
    uint32_t pos;           // read/write position
static struct rx_t {
    uint32_t cmdcnt;   // count of commands
    uint32_t errcnt;   // count of errors
    uint16_t cs;       // control/status image
    uint16_t es;       // error and status
    uint16_t tc;       // transfer count
    uint8_t  wc;       // word count
    uint8_t  ec;       // error code
    uint8_t  unit;     // active unit number
    uint8_t  den;      // density selected, SD, DD, QD
    uint8_t  type;     // emulation type: RX01, RX02
    uint8_t  timing;   // timing mode: 0=fastest, 2=normal/real
    struct {
        uint8_t code;  // function selected (numeric 0..7)
        char *  name;  // function selected, ascii name id
    } fcn;
    struct drv_t drv[RX_NUNITS]; // drive specific parameters
    uint8_t buffer[RX_BUFFER_SIZE]; // sector buffer
} rx;
static HardwareSerial *debugPort = NULL; // debug serial output
static uint8_t debugLevel = 0; // debug level, 0=NONE, higher is more
// RX02 INIT assertion interrupt
static void rx_intr_init (void)
    rx_init_seen = 1;
    return;
// RX02 RUN assertion interrupt
static void rx_intr_run (void)
    rx_run_seen = 1;
    return;
// RX time delay routine
static void rx_timing (uint8_t type)
    uint16_t delta;
    uint16_t ms_delay;
    const uint16_t ms_amount = 5;
    // check basic timing mode
    if (rx.timing >= 1) {
        // otherwise decode timing parameter
        switch (type) {
            case RX_TIME_INIT:
                ms_delay = 500;
                break;
            case RX_TIME_RDSTAT:
                ms_delay = 250;
                break;
            case RX_TIME_RDERROR:
                ms_delay = 10;
                break;
            case RX_TIME_SETMEDIA:
                ms_delay = 10000;
                break;
            case RX_TIME_SEEK:
                // compute track move delta
                delta = abs(rx.ta - rx.drv[rx.unit].ta);
                // compute seek time based on delta track amount
                ms_delay = 20 + ((delta==0) ? 0 : (20 + delta*10));
                break;
            // none
            default:
                ms_delay = 0;
                break;
        // for medium timing mode, make delays 1/10 of normal
        if (rx.timing == 1) ms_delay = ms_delay/10;
        // check for delay requested
        if (ms_delay > 0) {
            // delay in 5ms increments, checking for INIT
            while (ms_delay > ms_amount) {
                if (rx_init_seen) { longjmp(rx_init_env, 10); }
                delay(ms_amount);
                ms_delay -= ms_amount;
            // final small delay less than 5ms
            delay(ms_delay);
    // all done
    return;
// wait until the RX_RUN or RX_INIT signal is asserted, or timeout occurs
static uint8_t rx_wait_run_or_init (uint32_t expire)
    uint32_t start = millis();
    do {
        if (rx_init_seen) { rx_init_seen = 0; longjmp(rx_init_env, 1); }
        if (rx_run_seen) { rx_run_seen = 0; return RX_SAW_RUN; }
    } while (millis()-start <= expire);
    // count timed out with neither RUN or INIT
    return RX_SAW_NONE;
// wait forever until the RX_RUN or RX_INIT signal is asserted
static uint8_t rx_wait_run_or_init (void)
    do {
        if (rx_init_seen) { rx_init_seen = 0; longjmp(rx_init_env, 2); }
    } while (TRUE);
// receive a 12/8 bit word from the RX interface, msb first
#define _rx_recv_hs(xxx,yyy) { if (rx_tst_datai()) { delay_1c(); (xxx) |= (1<<(yyy)); } else { (xxx) &= ~(1<<(yyy)); delay_2c(); } delay_1c(); rx_set_shift(); delay_1c(); rx_clr_shift(); }
static uint16_t rx_recv12_hs (uint8_t handshake)
    uint16_t data = 0;
    rx_clr_out();
    rx_clr_done();
    rx_clr_datao();
    rx_clr_error();
    rx_clr_shift();
    if (handshake) { rx_set_request(); rx_wait_run_or_init(); rx_clr_request(); }
    noInterrupts();
    _rx_recv_hs(data,11);
    _rx_recv_hs(data,10);
    _rx_recv_hs(data,9);
    _rx_recv_hs(data,8);
    _rx_recv_hs(data,7);
    _rx_recv_hs(data,6);
    _rx_recv_hs(data,5);
    _rx_recv_hs(data,4);
    _rx_recv_hs(data,3);
    _rx_recv_hs(data,2);
    _rx_recv_hs(data,1);
    _rx_recv_hs(data,0);
    interrupts();
    if (rx_init_seen) { longjmp(rx_init_env, 3); }
    return data;
static uint16_t rx_recv8_hs (uint8_t handshake)
    uint8_t data = 0;
    rx_clr_out();
    rx_clr_done();
    rx_clr_datao();
    rx_clr_error();
    rx_clr_shift();
    noInterrupts();
    interrupts();
    if (rx_init_seen) { longjmp(rx_init_env, 4); }
    return uint16_t(data);
static uint16_t rx_recv (uint8_t n)
    if (n == 12)      return rx_recv12_hs(FALSE); else
    if (n ==  8)      return  rx_recv8_hs(FALSE); else
    if (rx_tst_12b()) return rx_recv12_hs(FALSE); else
static uint16_t rx_recv (void)
static uint16_t rx_recv_hs (uint8_t n)
    if (n == 12)      return rx_recv12_hs(TRUE); else
    if (n ==  8)      return  rx_recv8_hs(TRUE); else
    if (rx_tst_12b()) return rx_recv12_hs(TRUE); else
static uint16_t rx_recv_hs (void)
// transmit a 12/8 bit word to the RX interface, msb first
#define _rx_xmit_hs(xxx,yyy) { if ((xxx)&(1<<(yyy))) { delay_1c(); rx_set_datao(); } else { rx_clr_datao(); delay_2c(); } delay_1c(); rx_set_shift(); delay_1c(); rx_clr_shift(); }
static void rx_xmit12_hs (uint16_t value, uint8_t handshake)
    uint16_t data = value;
    noInterrupts();
    if (handshake) { rx_clr_request(); }
    rx_clr_shift();
    rx_set_out();
    delay_3c();
    _rx_xmit_hs(data,11);
    _rx_xmit_hs(data,10);
    _rx_xmit_hs(data,9);
    _rx_xmit_hs(data,8);
    _rx_xmit_hs(data,7);
    _rx_xmit_hs(data,6);
    _rx_xmit_hs(data,5);
    _rx_xmit_hs(data,4);
    _rx_xmit_hs(data,3);
    _rx_xmit_hs(data,2);
    _rx_xmit_hs(data,1);
    _rx_xmit_hs(data,0);
    delay_3c();
    rx_clr_datao();
    interrupts();
    rx_clr_out();
    if (rx_init_seen) { longjmp(rx_init_env, 5); }
    return;
static void rx_xmit8_hs (uint16_t value, uint8_t handshake)
    uint8_t data = value;
    noInterrupts();
    rx_clr_shift();
    rx_set_out();
    delay_3c();
    delay_3c();
    rx_clr_datao();
    interrupts();
    rx_clr_out();
    if (rx_init_seen) { longjmp(rx_init_env, 6); }
    return;
static void rx_xmit (uint16_t data, uint8_t n)
    if (n == 12)      rx_xmit12_hs(data,FALSE); else
    if (n ==  8)       rx_xmit8_hs(data,FALSE); else
    if (rx_tst_12b()) rx_xmit12_hs(data,FALSE); else
    return;
static void rx_xmit (uint16_t data)
    return;
static void rx_xmit_hs (uint16_t data, uint8_t n)
    if (n == 12)      rx_xmit12_hs(data,TRUE); else
    if (n ==  8)       rx_xmit8_hs(data,TRUE); else
    if (rx_tst_12b()) rx_xmit12_hs(data,TRUE); else
    return;
static void rx_xmit_hs (uint16_t data)
    return;
// transmit an extended status word
static void rx_xmit_es (void)
    if (debugLevel) debugPort->printf(F("RX: %s rx_xmit_es(%04o)\n\n"), rx.fcn.name, rx.es);
    if (rx_tst_dma() || rx_tst_12b() && rx.type == RX_TYPE_RX02) {
        // RX211/RXV21 or RX28 attached
        // clear TR, set DONE
        rx_clr_request();
        rx_set_out();
        rx_set_done();
        // send the 12b status word
        rx_xmit(rx.es, 12);
        // pulse TR high
        rx_set_request();
        rx_clr_request();
    } else if (rx_tst_12b()) {
        // RX8E attached
        rx_xmit(rx.es, 12);
     } else {
        // RX11/RXV11 attached
        // send the 8b status word
        rx_xmit(rx.es, 8);
    return;
// setup error/status word
static void rx_init_es (void)
    // setup initial value depending upon current function
    if (rx.fcn.code == RXFCN_FILL || rx.fcn.code == RXFCN_EMPTY) {
        // leave UNIT/DENSITY unchanged
        rx.es &= ~(RXES_UNITSEL|RXES_DRVDEN);
    } else {
        // clear all bits
        rx.es = 0;
    // for certain functions only
    if (rx.fcn.code == RXFCN_INIT || rx.fcn.code == RXFCN_RDSTAT) {
        // insert drive ready for that unit
        if (rx.drv[rx.unit].rdy) rx.es |= RXES_DRVRDY;
    // certain bits for RX02/RX03
    if (rx.type == RX_TYPE_RX02 || rx.type == RX_TYPE_RX03) {
        // insert drive type (RX28 only)
        if (rx_tst_12b()) rx.es |= RXES_RX02;
        if (!(rx.fcn.code == RXFCN_FILL || rx.fcn.code == RXFCN_EMPTY)) {
            // insert unit selected (RX211 only)
            if (rx.unit == 1 && rx_tst_dma()) rx.es |= RXES_UNITSEL;
            // insert density for that unit
            if (rx.drv[rx.unit].den == RX_DEN_DD) rx.es |= RXES_DRVDEN;
    // insert init done if in INITIALIZE state
    if (rx.fcn.code == RXFCN_INIT) rx.es |= RXES_INIT;
    // done
    return;
// PUBLIC PUBLIC PUBLIC PUBLIC PUBLIC PUBLIC PUBLIC PUBLIC PUBLIC PUBLIC
// initialize the RX subsystem
//    flag:  TRUE for powerup init; FALSE for INIT pulse seen
void rx_initialize (uint8_t flag)
    uint8_t i;
    // led status
    led_state(red, on);
    led_state(green, off);
    led_state(yellow, off);
    // setup at power up ... required first time only
    if (flag) {
        // setup pins
        pinMode(PIN_CTLR_DMA_MODE_L, INPUT);
        pinMode(PIN_CTLR_DATAI_H, INPUT);
        pinMode(PIN_CTLR_12BIT_H, INPUT);
        pinMode(PIN_CTLR_INIT_H, INPUT); // interrupt capable
        pinMode(PIN_CTLR_RUN_H, INPUT); // interrupt capable
        pinMode(PIN_CTLR_TR_RQST_H, OUTPUT);
        pinMode(PIN_CTLR_DATAO_H, OUTPUT);
        pinMode(PIN_CTLR_SHIFT_H, OUTPUT);
        pinMode(PIN_CTLR_ERROR_H, OUTPUT);
        pinMode(PIN_CTLR_ACLO_H, OUTPUT);
        pinMode(PIN_CTLR_DONE_H, OUTPUT);
        pinMode(PIN_CTLR_OUT_H, OUTPUT);
        // setup RX INIT interrupt
        rx_init_seen = 0;
        attachInterrupt(digitalPinToInterrupt(PIN_CTLR_INIT_H), rx_intr_init, RISING);
        // setup RX RUN interrupt
        rx_run_seen = 0;
        attachInterrupt(digitalPinToInterrupt(PIN_CTLR_RUN_H), rx_intr_run, RISING);
        // counters
        rx.cmdcnt = 0;
        rx.errcnt = 0;
    // setup control outputs
    rx_clr_out();
    rx_clr_aclo();
    rx_clr_done();
    rx_clr_datao();
    rx_clr_error();
    rx_clr_shift();
    rx_clr_request();
    // toggle ACLO at initial reset
    if (flag) { rx_set_aclo(); delay(100); rx_clr_aclo(); }
    // wait for INIT to go away
    uint32_t start = millis(); // current time, in ms
    uint32_t expire = 10000UL; // 10 sec delay
    if (debugLevel) debugPort->printf(F("RX: waiting for INIT to clear ... t=%lums\n"), millis());
    while ((rx_init_seen || rx_tst_init()) && millis()-start <= expire) { rx_init_seen = 0; }
    if (debugLevel) debugPort->printf(F("RX: INIT has %scleared t=%lums\n"), rx_tst_init() ? "NOT " : "", millis());
    // setup drive data structures
    rx.type = rx_type;
    rx.fcn.code = RXFCN_INIT;
    rx.fcn.name = fcn_list[rx.fcn.code];
    rx.den = (rx.type == RX_TYPE_RX02 ? RX_DEN_DD : RX_DEN_SD);
    rx.cs = 0;
    rx.es = 0;
    rx.ec = 0;
    rx.ta = 0;
    rx.sa = 0;
    rx.wc = 0;
    rx.tc = 0;
    rx.len = 0;
    rx.pos = 0;
    rx.unit = 0;
    rx.timing = 0;
    // setup drive state
    for (i = 0; i < RX_NUNITS; ++i) {
        if (flag) sprintf(rx.drv[i].name, "RX%d.DSK", i);
        rx_unit_file(i);
    // clear entire sector buffer
    memset(rx.buffer, 0x00, sizeof(rx.buffer));
    // indicate SD card access in progress
    led_state(yellow, on);
    // copy drive 0 boot sector into the buffer, if drive is ready
    rx.drv[0].ta  = rx.ta = 1;
    rx.drv[0].sa  = rx.sa = 1;
    rx.drv[0].len = rx.len = rx_sec_size(rx.drv[0].den);
    rx.drv[0].pos = rx.pos = (rx.ta*RX_NSECS + (rx.sa - 1)) * rx.len;
    if (rx.drv[0].rdy) sd_read_bytes(rx.drv[0].name, rx.pos, rx.buffer, rx.len);
    // indicate SD card access complete
    // init time delay
    rx_timing(RX_TIME_INIT);
    // setup error/status bits and transmit
    rx_init_es();
    rx_xmit_es();
    // led status
    led_state(red, off);
    return;
// setup the file for rx drive unit
char *rx_unit_file (uint8_t unit, char *name)
    uint32_t size;
    // setup file name if provided
    if (name) strcpy(rx.drv[unit].name, name);
    // set initial state from common block
    rx.drv[unit].ta  = rx.ta;
    rx.drv[unit].sa  = rx.sa;
    rx.drv[unit].len = rx.len;
    rx.drv[unit].pos = rx.pos;
    // zap the deleted data state to normal
    memset(rx.drv[unit].dd, RX_DATA_NORMAL, sizeof(rx.drv[unit].dd));
    // special file name of "NONE" (any capitalization) maps to an unmounted drive
    if (strcasecmp(rx.drv[unit].name, "NONE") == 0) {
        // no online disk
        rx.drv[unit].rdy = FALSE;
        rx.drv[unit].den = RX_DEN_SD;
        // return the name
        return rx.drv[unit].name;
    // get size of (existing) file, check it for SD or DD or none; if not SD (RX01,RX02) or DD (RX02) then set it
    size = sd_get_file_size(rx.drv[unit].name);
    if (rx.type == RX_TYPE_RX01) {
        // RX01 only supports SD disks
        if (size != rx_dsk_size(RX_DEN_SD))
            size = sd_set_file_size(rx.drv[unit].name, rx_dsk_size(RX_DEN_SD));
    } else {
        // RX02/RX03 supports SD or DD disks, default to DD
        if (size != rx_dsk_size(RX_DEN_SD) && size != rx_dsk_size(RX_DEN_DD))
            size = sd_set_file_size(rx.drv[unit].name, rx_dsk_size(RX_DEN_DD));
    // set drive ready if file exists and is a right size (SD or DD)
    rx.drv[unit].rdy = (size == rx_dsk_size(RX_DEN_SD)) || (size == rx_dsk_size(RX_DEN_DD));
    // set drive density based on file size
    rx.drv[unit].den = (size == rx_dsk_size(RX_DEN_DD)) ? RX_DEN_DD : RX_DEN_SD;
    // return the name
// setup drive for unit using existing file name
char * rx_unit_file (uint8_t unit)
    return rx_unit_file(unit, NULL);
// setup the default emulation type (1=RX01, 2=RX02, etc)
uint8_t rx_emulation_type (uint8_t type)
    rx.type = rx_type = type;
    return rx.type;
uint8_t rx_emulation_type (void)
    return rx.type;
// setup the default timing type (-1=N/C, 0=fastest, 1=medium, 2=slow/normal)
uint8_t rx_timing_type (uint8_t type)
    rx.timing = type;
    return rx.timing;
uint8_t rx_timing_type (void)
    return rx.timing;
// setup the RX02 subsystem debug port
uint8_t rx_debug (HardwareSerial *serialPort, uint8_t level)
    // set debug serial port (or not)
    debugPort = serialPort;
    // and the debug level
    debugLevel = level;
    // and done
    return debugLevel;
uint8_t rx_debug (void)
    return debugLevel;
// print RX emulator state
void rx_print_state (HardwareSerial *prt)
    uint8_t i;
    // dump to user supplied port if not null
    if (prt == NULL) prt = debugPort;
    // else try debug port, else return
    if (prt == NULL) return;
    prt->printf(F("\n\n--- RX Emulator State Dump ---\n\n"));
    prt->printf(F("    i/f width = %d.\n"),   rx_get_bits());
    prt->printf(F("     i/f mode = %s\n"),    rx_tst_dma() ? "DMA" : "PIO");
    prt->printf(F("     i/f init = %o\n"),    rx_tst_init());
    prt->printf(F("      i/f run = %o\n"),    rx_tst_run());
    prt->printf(F("\n"));
    prt->printf(F("        rx.cs = %06o\n"),  rx.cs);
    prt->printf(F("        rx.es = %04o\n"),  rx.es);
    prt->printf(F("        rx.ec = %04o\n"),  rx.ec);
    prt->printf(F("        rx.wc = %03o\n"),  rx.wc);
    prt->printf(F("        rx.tc = %03o\n"),  rx.tc);
    prt->printf(F("        rx.ta = %03o\n"),  rx.ta);
    prt->printf(F("        rx.sa = %03o\n"),  rx.sa);
    prt->printf(F("       rx.pos = %lu.\n"),  rx.pos);
    prt->printf(F("       rx.len = %u.\n"),   rx.len);
    prt->printf(F("       rx.den = %c\n"),    den_list[rx.den]);
    prt->printf(F("      rx.unit = %o\n"),    rx.unit);
    prt->printf(F("      rx.type = RX0%d\n"), rx.type);
    prt->printf(F("    rx.cmdcnt = %u.\n"),   rx.cmdcnt);
    prt->printf(F("    rx.errcnt = %u.\n"),   rx.errcnt);
    prt->printf(F("    rx.timing = %o\n"),    rx.timing);
    prt->printf(F("  rx.fcn.code = %o\n"),    rx.fcn.code);
    prt->printf(F("  rx.fcn.name = %s\n"),    rx.fcn.name);
        prt->printf(F("    rx.drv[%d].name = '%s'\n"), i, rx.drv[i].name);
        prt->printf(F("     rx.drv[%d].rdy = %c\n"),   i, rx.drv[i].rdy ? 'Y' : 'N');
        prt->printf(F("     rx.drv[%d].den = %c\n"),   i, den_list[rx.drv[i].den]);
        prt->printf(F("      rx.drv[%d].ta = %03o\n"), i, rx.drv[i].ta);
        prt->printf(F("      rx.drv[%d].sa = %03o\n"), i, rx.drv[i].sa);
        prt->printf(F("     rx.drv[%d].pos = %lu.\n"), i, rx.drv[i].pos);
        prt->printf(F("     rx.drv[%d].len = %u.\n"),  i, rx.drv[i].len);
    return;
// execute an RX function ... the mainline RX emulator routine, executes one command
void rx_function (void)
    uint16_t i, j;
    uint16_t value;
    // setup for a new request
    rx_clr_request();
    rx_clr_out();
    rx_set_done();
    // setup INIT seen callback
    if (setjmp(rx_init_env)) {
        // return to here on longjmp(rx_init_env,N);
        rx_init_seen = 0;
        rx_initialize(false);
        return;
    // wait for RUN or INIT; 25ms timeout if no RUN or INIT
    if (rx_wait_run_or_init(25) == RX_SAW_NONE) return;
    // RUN seen, process command ...
    // receive a command word: 12b on RX211 or RX8E/28 in 12b mode; 8b otherwise
    rx.cs = rx_recv(rx_tst_dma() || rx_tst_12b() ? 12 : 8);
    if (debugLevel) debugPort->printf(F("RX: cmd=%04o\n"), rx.cs);
    // led status
    led_state(green, on);
    // separate out the function field
    rx.fcn.code = (rx.cs & RXCS_FUNCTION)>>1;
    // separate out the unit number in the command
    rx.unit = (rx.cs & RXCS_UNITSEL) ? 1 : 0;
    // separate out the density flag in the command
    rx.den = (rx.cs & RXCS_DENSEL) ? RX_DEN_DD : RX_DEN_SD;
	// initial error code: success!
	rx.ec = RXERR_SUCCESS;
    // initial error status
    rx_init_es();
    // print command
    if (debugLevel) debugPort->printf(F("RX: %s unit=%o den=%c\n"), rx.fcn.name, rx.unit, den_list[rx.den]);
    // decode command function
    switch (rx.fcn.code) {
    // === buffer fill or empty ===
    // DMA: command(12), wordcount(8), N*databytes(8)
    // PIO: command(12), N*databytes(8 or 12)
    case RXFCN_FILL:
    case RXFCN_EMPTY:
        // compute word count
        if (rx_tst_dma()) {
            // if DMA mode, receive word count from interface
            rx.wc = rx_recv_hs(8);
            // receive bus address
            // rx.ba = rx_recv_hs(16); // done in RX211 hardware
        } else {
            // if PIO mode, compute word count from full sector size
            rx.wc = rx_sec_size(rx.den) >> (rx_tst_8b() ? 1 : 2);
        if (debugLevel) debugPort->printf(F("RX: %s wc=%03o\n"), rx.fcn.name, rx.wc);
        // transform word count to transfer count
        rx.tc = 2*rx.wc;
        // check for word count overflow (only can happen on RX211 dma interface with user word count)
        if (rx.tc > rx_sec_size(rx.den)) {
            if (debugLevel) debugPort->printf(F("RX: %s wc=%03o WCOVF\n"), rx.fcn.name, rx.wc);
            rx.ec = RXERR_WCOVF;
            rx.es |= RXES_WCOVF;
            goto error;
        // transfer data words in/out
        if (rx.fcn.code == RXFCN_EMPTY) {
            // empty buffer (RX controller buffer to host interface)
            for (i = j = 0; i < rx.tc; ++i) {
                if (rx_tst_8b()) {
                    // extract 8b values from buffer to send as 8b
                    value = rx.buffer[i];
                    rx_xmit_hs(value, 8);
                } else {
                    // 12b values are packed into the first 2/3 of the sector; read 2 8b entries and build 12b value
                    j = 3*i/2;
                    if (i & 1) {
                        // odd byte
                        value = ((rx.buffer[j+0] & 017) << 8) | rx.buffer[j+1];
                    } else {
                        // even byte
                        value = (rx.buffer[j+0] << 4) | ((rx.buffer[j+1] >> 4) & 017);
                    rx_xmit_hs(value, 12);
                if (debugLevel >= 2) {
                    if ((i & 7) == 0) debugPort->printf(F("RX: %s %03o:"), rx.fcn.name, i);
                    if (rx_tst_8b())  debugPort->printf(F(" %03o"), value); else debugPort->printf(F(" %04o"), value);
                    if ((i & 7) == 7) debugPort->printf(F("\n"));
            } // for (i = 0; i < rx.tc; ++i)
            if (debugLevel >= 2 && (i & 7) != 0) debugPort->printf(F("\n"));
        } else {
            // fill buffer (host interface to RX controller buffer)
                if (rx_tst_8b()) {
                    // 8b values get stuffed into 8b buffer directly
                    value = rx_recv_hs(8);
                    rx.buffer[i] = value;
                    j = i+1;
                } else {
                    // 12b values get split into 4b/8b and merged into two 8b entries
                    value = rx_recv_hs(12);
                    j = 3*i/2;
                    if (i & 1) {
                        // odd byte
                        rx.buffer[j++] |= (value >> 8) & 017;
                        rx.buffer[j++] = value;
                    } else {
                        // even byte
                        rx.buffer[j++] = value >> 4;
                        rx.buffer[j++] = (value & 017) << 4;
            if (debugLevel >= 2 && j < rx_sec_size(rx.den))
                debugPort->printf(F("RX: %s zero fill buffer %03o..%03o\n"), rx.fcn.name, j, rx_sec_size(rx.den)-1);
            // zero fill any unwritten bytes at the end of the buffer up to the sector size
            while  (j < rx_sec_size(rx.den)) rx.buffer[j++] = 0;
        // indicate transfer is complete
        rx.wc = 0;
        break;
    // === read/write sector ===
    // command(12), sector(8 or 12), track(8 or 12)
    case RXFCN_RDSECT:
    case RXFCN_WRSECT:
    case RXFCN_WRDDSECT:
        // first word is sector address (001..032 are valid)
        rx.sa = rx_recv_hs() & 0077;
        if (debugLevel) debugPort->printf(F("RX: %s sa=%03o\n"), rx.fcn.name, rx.sa);
        // second word is track address (000..114 are valid)
        rx.ta = rx_recv_hs() & 0377;
        if (debugLevel) debugPort->printf(F("RX: %s ta=%03o\n"), rx.fcn.name, rx.ta);
        // check drive is ready
        if (!rx.drv[rx.unit].rdy) {
            // nope, error
            goto error;
        // check track access is valid
        if (rx.ta >= RX_NTRKS) {
            rx.ec = RXERR_TRKERR;
            goto error;
        // check density matches, error if does not
        if (rx.den != rx.drv[rx.unit].den) {
            rx.ec = RXERR_DENERR;
            rx.es |= RXES_DENERR;
            goto error;
        // check sector address is valid
        if (rx.sa < 1 || rx.sa > RX_NSECS) {
            rx.ec = RXERR_SECFAIL;
            goto error;
        // compute length of transfer (sector size)
        rx.len = rx_sec_size(rx.drv[rx.unit].den);
        // compute byte offset into disk image
        rx.pos = (rx.ta*RX_NSECS + (rx.sa-1)) * rx.len;
        // print details if in debug mode
        if (debugLevel) debugPort->printf(F("RX: %s pos=%lu. len=%u.\n"), rx.fcn.name, rx.pos, rx.len);
        // bail on INIT seen
        if (rx_init_seen) { longjmp(rx_init_env, 20); }
        // do the read or write
        if (rx.fcn.code == RXFCN_RDSECT) {
            // do a read; copy data into buffer from diskimage@offset
            value = sd_read_bytes(rx.drv[rx.unit].name, rx.pos, rx.buffer, rx.len);
        } else {
            // do a write
            if (rx.fcn.code == RXFCN_WRDDSECT) {
                bitWrite(rx.drv[rx.unit].dd[rx.ta], rx.sa, RX_DATA_DELETED);
            } else {
                bitWrite(rx.drv[rx.unit].dd[rx.ta], rx.sa, RX_DATA_NORMAL);
            // copy data from rx.buffer[] to diskimage@offset
            value = sd_write_bytes(rx.drv[rx.unit].name, rx.pos, rx.buffer, rx.len);
        // set deleted data status based on sector written or read deldata status
        if (bitRead(rx.drv[rx.unit].dd[rx.ta], rx.sa) == RX_DATA_DELETED) rx.es |= RXES_DELDATA;
        // SD card access complete
        // simulate timing
        rx_timing(RX_TIME_SEEK);
        // update state info for drive
        rx.drv[rx.unit].ta = rx.ta;
        rx.drv[rx.unit].sa = rx.sa;
        rx.drv[rx.unit].pos = rx.pos;
        rx.drv[rx.unit].len = rx.len;
        // check for read/write error
        if (value != rx.len) {
            rx.ec = RXERR_IDMFAIL;
            goto error;
        // and done
        break;
    // === set media density ===
    // command(12), key(8 or 12)
    case RXFCN_SETMEDIA:
        // this function is a NOP for the RX01
        if (rx.type == RX_TYPE_RX01) break;
        // first word must be the magic key 'I'
        value = rx_recv_hs();
        // check key for expected value
        if (value != 'I') {
            rx.ec = RXERR_KEYERR;
            goto error;
            // nope, error
            goto error;
        // simulate timing
        rx_timing(RX_TIME_SETMEDIA);
        if (rx_init_seen) { longjmp(rx_init_env, 21); }
        // change density to requested value AND always zero the entire disk image
        sd_set_file_size(rx.drv[rx.unit].name, rx_dsk_size(rx.den));
        // update disk parameters to match new size
        rx_unit_file(rx.unit);
        // update status since may have changed unit density
        rx_init_es();
        // and done
        break;
    // === read status ===
    // command(12)
    case RXFCN_RDSTAT:
        // simulate timing
        rx_timing(RX_TIME_RDSTAT);
        // and done
        break;
    // === read error code ===
    // command(12)
    case RXFCN_RDERROR:
        if (rx_tst_dma()) {
            // RX211/RXV21; return four 16b status words
            // simulate timing
            rx_timing(RX_TIME_RDERROR);
            // generate status byte
            value = (rx.unit == 1               ? (1<<7) : 0)
                  | (rx.drv[1].den == RX_DEN_DD ? (1<<6) : 0)
                  | (rx.drv[rx.unit].rdy        ? (1<<5) : 0)
                  | (rx.drv[0].den == RX_DEN_DD ? (1<<4) : 0)
                  | (rx.den == RX_DEN_DD        ? (1<<0) : 0);
            // print error block
                debugPort->printf(F("RX: %s Word%d: %03o %03o\n"), rx.fcn.name, 1, rx.wc,              rx.ec);
                debugPort->printf(F("RX: %s Word%d: %03o %03o\n"), rx.fcn.name, 2, rx.drv[1].ta,       rx.drv[0].ta);
                debugPort->printf(F("RX: %s Word%d: %03o %03o\n"), rx.fcn.name, 3, rx.sa,              rx.ta);
                debugPort->printf(F("RX: %s Word%d: %03o %03o\n"), rx.fcn.name, 4, rx.drv[rx.unit].ta, value);
            // word 1
            rx_xmit_hs(rx.ec, 8);
            rx_xmit_hs(rx.wc, 8);
            // word 2
            rx_xmit_hs(rx.drv[0].ta, 8);
            rx_xmit_hs(rx.drv[1].ta, 8);
            // word 3
            rx_xmit_hs(rx.ta, 8);
            rx_xmit_hs(rx.sa, 8);
            // word 4
            rx_xmit_hs(rx.drv[rx.unit].ta, 8);
        } else if (rx.type == RX_TYPE_RX01) {
            // RX11/RXV11/RX8E; return EC register in DB
            // return EC instead of ES
            rx.es = rx.ec;
        // and done
        break;
    } // switch (rx.fcn.num)
done:
    rx.cmdcnt++;
    rx_xmit_es();
    return;
error:
    rx.errcnt++;
    rx_set_error();
    led_state(red, on);
    goto done;
// the end
FYI here is the Arduino mega shield I did thru OshPark: https://oshpark.com/shared_projects/NZJU7bbG
Here is the schematic and PCB layout (in acrobat), for reference: https://drive.google.com/open?id=0B7Csc-dWWfTYR3plTmtWd2VtWlU
As a low volume fast turn proto it is rather pricey (about $28 ea in QTY of three) so others might want to investigate alternative shield solutions using the discrete transistor approach. I found it easier to just use the 8641 as was done in original DEC hardware (and I have a NOS supply of these devices available). So most likely others will go a different route for the shield design.
I did a four layer board (my first thru OshPark) mainly because I was lazy and did not want to deal with power distribution routing, and needed an excuse to try out their four layer capability (I have done a number of two layer boards thru them).
I used three 8641 devices as the driver/receiver chips, added a couple of FTDI cable USB serial footprints (currently not used) and a footprint for a Sparkfun MicroSD breakout board, plus three status LEDs.
I did not provide any direct access for an LCD display (personally I find these rather useless for this application, just my opinion) since I always tether the device to a PC to get power for it (and then just open up a terminal window to control it).
I've done a new shield design, replacing the 3x8641 with 7x2N7000/1x74HC14 to see how that works.
It is in fab now at OshPark, will have back in a couple of weeks or so for testing. It is 100% software compatible with the current shield.
2N7000/HC14-based image: https://644db4de3505c40a0444-327723...kcdn.com/bec3765cfecc8099e2b9fdae198a665e.png
8641-based image: https://644db4de3505c40a0444-327723...kcdn.com/6f0639d63d31e57aae6645db0be3599d.png
Don
Created a GITHUB project for the full design, with all relevant files: https://github.com/AK6DN/rx02_emulator
Is your code GPL-compatible? I am working on RX11/RX01 simulator for MAME, your emulator could be useful as reference, or even as straight reuse.
I've tagged it with the same copyright/licensing as used in the main body of SIMH code.
That being said, as an RX01/RX11 simulator, it is (probably) not what you are really looking for. This is a low level emulator that mimics the hardware interface protocol between an interface card in a PDP-11 system (ie, RX211, RX11, RXV21, RXV11) or PDP-8 system (RX28/RX8E) and an attached RX01/RX02 drive assembly.
I suspect what you are really looking for is a full software emulation, including the interface and controller, which would be more like the RX01 emulator file in the SIMH source tree ( https://github.com/simh/simh/blob/master/PDP11/pdp11_rx.c ) which is a full emulation of an RX11/RX01 interface, controller, and drive.
Don
Actually, that is exactly what MAME aims to do -- emulate everything at lowest level possible, as accurate as possible. I am doing a high-level emulation first, to understand how the hardware works, and next step would be to emulate the microcontroller in the drive, and serial interface between it and the host.
Ok, got it. That is a very ambitious project, then. There is a whole other microprogrammed controller within the RX01/2 drive itself (a custom bit slice design) that is actually doing all the 'same' functionality (plus a LOT more) that the RX02_emulator Arduino code does (ie, it has to encode/decode/process the raw digital bitstream of the drive electronics).
So I guess it depends on how low a level you really intend to go.
Don
Hopefully, down to the MFM flux transition level -- MAME's got code to deal with that, for floppies and hard drives alike.
Well that is very ambitious indeed. Luckily DEC produced some very good technical documentation and schematics that are still available for all the relevant hardware.
Right, and many thanks to everyone who made that documentation available online. Some progress -- my HLE version is passing ZRXAF0 test but fails ZRXBF0:
ZRXA is the RX01/RX11 performance exerciser (like ZRXD for the RX02/RX211), which basically just does regular read/writes of various data patterns to a disk and compares data written vs read. This is a fairly high level test, and if your emulation is basically functional this one will pass.
ZRXB is the RX01/RX11 low level hardware interface test (like ZRXF for the RX02/RX211) which checks all the nitty gritty details of all the status bits returned on all kinds of functions, both legal and illegal, meaning expected to generate errors. Your emulation has to be flawless match to the original hardware to get thru this one.
I wish I had access to an RX11 for the UNIBUS so I could actually test my emulator in this mode and run ZRXA/ZRXB, but alas I do not have one of these boards.
... Well looks like my list of boards says I have a UNIBUS RX11 stashed away somewhere ... now I just have to find it.
Found it, but it is the only one I have, and it is non-functional. My PDP-11/44 won't boot with it in the chassis. So I will need to repair it before I can do RX11/RX01 testing ...
Well, the bug was as subtle as it was simple to fix -- I'd missed one state machine transition at the end of 'empty' command. Now ZRXB passes flawlessly. Equivalent tests from Elektronika-60 test suite (014101, 014102) also pass -- no surprise there, as they were likely built from same source code, with messages translated into Russian:
Don
Don,
Yesterday I received the PC boards made for the 8641 chips from OshPark. In an email from them they mentioned that they had 33 orders for your RX02 emulator board with 246 boards in total. Thus, there are a lot of us interested in your project here. I have the Ardiuno Mega 256 and was able to find the 8641 chips, and have soldered everything together except for the SD card header which I ordered yesterday.
I've soldered everything in place except for the P8 and P9 headers. Here I wondered if you had a recommendation for the UART to USB or RS232 cable/adapter that worked well with the Mega 256?
Second question is in your rx02_emulator_sch_v3_8641.pdf there is a table for "Termination Resistor Stuff Table" and the "RX Drive Interface 40p Header" with the Note: That selective stuff resistors depending on usage. I plan to use this with a RXV21 controller on a MINC-23. I assume that I need to only solder in the resistors in the Table and where "nostuff" is stated as the value I'd leave empty?
I also thought about soldering in two 22 pin header/sockets so that I could add / remove resistors if they might change in moving the RX02 emulator between a RXV21 (M8029) and a RX211 (M8256) that I might some day have connected to a PDP-11/05 if I ever get it running. Would socketing the resistors be worth while?
Lastly, I see you may sometime get the TU58 code also working. This would be great! Also, A LCD display would be great if there are enough I/O pins left available to drive it.
Thank you very much for extending the previous work from CH Dickman ( http://www.chdickman.com/rx02/ ) and Bella to your PCB Board design and GitHub code!!!
Mark
Don,
All I can say to this is holy crap, batman, I had no idea there was this must interest! Not a clue this was going on. There is no communication I have had back from OshPark saying my 'shared design' was being ordered (or how many). The only other activity has been messages on this board, but most posters said they have been watching, none have said anything about building copies, until now.
The SD card header I use is a microSD card breakout board (https://www.sparkfun.com/products/13743) for $4.95 which has the level shifting logic on it. I have a bunch of these, they are very useful little boards.
I just got back both a set of 10 v3 (8641) and v4 (2N7000) based boards from Dangerous Prototypes. I sent the same gerbers to them as OshPark, and they produced 10 copies of the board for about $4.50 each, plus an additional $2.00 each for expedited shipping (vs about $26 each using OshPark). Not pretty purple and gold, but green and silver, and much less costly.
I made the footprint compatible with this: https://www.sparkfun.com/products/9718 which is a standard FTDI 5V usb/serial cable. This cable is not necessary for the current implementation (ie, RX02 to SDcard) but was added for someday adding the RX02 to serial interface capability, somewhat how TU58EM operates.
That is correct. I basically put locations for a pullup/pulldown for all the RX interface lines, but in reality only those that are listed in the table need to be stuffed as indicated. This table represents how a physical RX02/RX01 drive handle the termination.
I don't believe socketing the resistors is useful, I just solder the resistors in directly. There is no reason the resistor stuffing or values should have to change for any application (RX211, RX11, RXV21, RXV11, and RX8E/RX28) on the computer interface side.
Yes, I have tested out all the TU58 serial driver code on the Arduino in a standalone test program so it works to issue read/write requests to a backend TU58EM server on a PC. I have not yet integrated it as a replacement for SD card access, preferring to concentrate on getting the RX01/2 emulation rock solid first, first on the RX211 (done I believe) and next the RX8E/RX28.
My general thought is to allow specifying a pseudo-filename like 'serial0' to 'serial7' as the RX02 file, and this would then map to the backend TU58EM emulated TU58 drive 0 thru 7. So then could have a local SDcard file on unit 0, and a backend file accessed on a PC thru TU58EM (which would actually be a byte for byte image of an RX01/RX02 file). That's the general plan, anyway.
There are LOTS of I/O pins left available on the various headers, so adding additional features like an LCD display should not be difficult.
Mark
I just uploaded/checked the design documentation (schematic, PCB layout) for both the v3 (8641) and v4 (2n7K discrete) boards on my google drive:
Note I also added the full gerbers for the rev1 layouts of each of v3 (8641) and v4 (2n7k) designs. Altho I really like OSHpark quality, I also did a test run thru:
http://dangerousprototypes.com/store/pcbs
where for the ProtoPack+/-10 service you can get a 4 layer 10x10cm board for $44.95 (for ~10 boards, about $5 per board). They are green soldermask plus HASL (not ENIG) but look good.
FYI the updated OSHpark v4rev1 2n7k-based design is: https://oshpark.com/shared_projects/2l0ZHhgv
and the updated OSHpark v3rev1 8641-based design is: https://oshpark.com/shared_projects/Pyy6GQOC
These have the LED resistors and the USB serial connector footprints relocated around the baseboard Mega2560 USB connector shell.
Note there are both rev0 and rev1 PCB layouts. In the rev0 versions I found that the FTDI headers were placed directly over the USB power connector shell on the standard Arduino Mega2560 layout (as well as part of the LED current limit resistors footprint). I didn't find this originally aas I was using a version of the Mega2560 that had a miniUSB power connector, not standard USB.
So for the rev1 board designs I just moved the two UART connector footprints away from the USB connector area (implemented on both v3rev1 and v4rev1 board designs). The schematics did not change, only a minor tweak to the layout in the 'left side' of the layout near the USB serial connector footprints.
I uploaded the new rev1 v3 and v4 layouts to OSHpark a week or so ago (to replace the older v3/v4 layouts) so depending on when you ordered from OSHpark you may get rev0 boards.
To work around the USB serial footprint / led resistor vs USB shell mechanical collision, the solution I use is to add 0.5" standoffs between my Mega2560 and the RX02 emulator shield to prevent the shorting to the metal case of the USB connector on the Mega2560. So instead of the shield being fully seated onto the Mega2560, it rides up 0.5" over it. The connector pins are long enough to handle this 50-100mil extra spacing.
Here is the Mega2560 I have with the miniUSB power connector. Turns out this is not the standard variation:
Here is the Mega2560 with the standard USB.A power connector. I put the RX02 shield on 0.5" standoffs and put Kapton tape (not really necessary with the standoffs) on the USB power shell.
Just received my v4rev1 boards from DangerousPrototypes today, and built the first one up. This one uses 2N7000 discrete transistors and a 74HC14 vs the three 8641 transceivers.
Here is a pix of the assembled unit:
You can see that I replaced the 3x8641 with 7x2N7000+1x74HC14, and that I moved the USB serial connectors around on the left side to have them not collide with the USB connector.
I have run this design thru the same tests (DEC diagnostics ZRXD rx02/rx211 perf test, ZRXF rx211/rx02 hdwe diag, and booting XXDP and RT11 images) as the v3 8641 design, and it performs the same.
All the tests pass successfully. Note the board is green soldermask as opposed to the OshPark purple.
At this point I have *eight* extra of the v4rev1 boards (exactly like the last picture above) and am willing to part with them for $7.50 each plus shipping (about $2.50 US; more for international). $5 more for a SparkFun microSD adapter. So $15.00 in paypal for the combo. First eight PMs I get that are interested can have them.
Don
RX02 Emulation
RX02 Emulation
Don
Don,
Thank you very much for the detailed post with the photos and links for the SDcard adapter and serial port cable. I was also amazed at the orders placed at OshPark! I'd also point out that I placed my order pretty early so there well could be additional orders after that! Mine was early enough that it was the rev board so the info about the spacer a tape is appreciated. I had not noticed the possible contact between the larger USB metal shell and the PCB. I do have my Mega 256 in a small clear acrylic case and they may prevent them from touching. (I'm on the road this week and can't check it at the moment).
I am amazed at the level of interest in DEC PDP-8 and PDP-11 retro computing. This project is a good one as there are many more working RX controller boards that there are working RX01 and RX02 disks. On Qbus the SCSI controllers although not cheap are at least available. The Unibus SCSI controllers are much more difficult to find and afford. Also, not all hardware has boot roms for DU, but DX and DY are so if you want to run RT-11 in limited memory this is THE way to go.
Thanks again for the detailed post as it will help many of us get your design into operation.
Best,
Mark
P.S. I did send you a PM about the v4rev1 boards last night so hopefully I was one of the first eight.
Don,
Best,
Mark
You are. At this point there are only *1* of the available v4rev1 boards unspoken for.
However, I just sent a couple of 10 board runs of each of the v4rev1 and v3rev1 off to Dangerous Prototypes so I should have these in about 10 days (based on last run).
Yes I was very surprised about the reported OshPark orders as there was no indication there was that much interest in this project in this thread. Lots of 'lurkers' :-) I guess.
Don
Don
Don,
I got the v4rev1 board you sent with the SDcard adapter today. Using a couple punch cards as packing for the PCB was a very nice touch!
I had assembled the original v3rev0 board using electrical tape and a bit of a spacer to prevent any contact between the LED resistors and the USB housing. I hadn't got the SDcard adapter from Sparkfun I ordered earlier yet, so when the one you sent came I could complete one emulator.
The issue I have as an Arduino newbie is I can't figure out how to do what you say in Note 1 from what is written at http://playground.arduino.cc/Main/Printf ???
(1) This code has been written with the assumption that Xprintf support has been added to the PRINT class in the Arduino development environment. Refer to: http://playground.arduino.cc/Main/Printf for instructions on how to do this.
I was able to get Note 2's addition of the SdFat library and now I don't get compile errors for it. I am using V1.6.12 of the Arduino IDE if that matters.
On my SDcard I have blank RX0.DSK and RX1.DSK files that I plan to INIT and COPY files to from a running RT-11 that boots from DU media on a SCSI2SD / UC07 drive.
There may be a bunch of 'Lurkers' who will soon be scratching their heads too unless they are more proficient with Arduino's IDE than I am.
Thanks for your help!
Mark
Ok, to add the 'printf/sprintf' capability to the print class, here is what I did per those referenced instructions:
1) open folder: "C:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" (not exactly the same path as indicated in the note)
2) there should be a file: Print.h in that directory
3) save a copy of that file (in case you screw up) as something like: Print.h.asd
4) open the file Print.h for editing, and add the referenced lines (as I indicate in bold/red, below, same as from the web page) near the end, as indicated
5) close the file, you should now be able to relaunch the Ardunio IDE and compile error free
Here is my edited Print.h file. Most likely yours will be EXACTLY the same, as this file does not seem to change very often, if at all.
I currently am using Arduino 1.6.8 which is a bit older but I don't think that 1.6.12 should be an issue.
Don
  Print.h - Base class that provides print() and println()
  Copyright (c) 2008 David A. Mellis.  All right reserved.
  This library is free software; you can redistribute it and/or
  modify it under the terms of the GNU Lesser General Public
  License as published by the Free Software Foundation; either
  version 2.1 of the License, or (at your option) any later version.
  This library is distributed in the hope that it will be useful,
  but WITHOUT ANY WARRANTY; without even the implied warranty of
  MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the GNU
  Lesser General Public License for more details.
  You should have received a copy of the GNU Lesser General Public
  License along with this library; if not, write to the Free Software
  Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA  02110-1301  USA
#ifndef Print_h
#define Print_h
#include <inttypes.h>
#include <stdio.h> // for size_t
#include "WString.h"
#include "Printable.h"
#define DEC 10
#define HEX 16
#define OCT 8
#define BIN 2
class Print
  private:
    int write_error;
    size_t printNumber(unsigned long, uint8_t);
    size_t printFloat(double, uint8_t);
  protected:
    void setWriteError(int err = 1) { write_error = err; }
  public:
    Print() : write_error(0) {}
    int getWriteError() { return write_error; }
    void clearWriteError() { setWriteError(0); }
    virtual size_t write(uint8_t) = 0;
    size_t write(const char *str) {
      if (str == NULL) return 0;
      return write((const uint8_t *)str, strlen(str));
    virtual size_t write(const uint8_t *buffer, size_t size);
    size_t write(const char *buffer, size_t size) {
      return write((const uint8_t *)buffer, size);
    size_t print(const __FlashStringHelper *);
    size_t print(const String &);
    size_t print(const char[]);
    size_t print(char);
    size_t print(unsigned char, int = DEC);
    size_t print(int, int = DEC);
    size_t print(unsigned int, int = DEC);
    size_t print(long, int = DEC);
    size_t print(unsigned long, int = DEC);
    size_t print(double, int = 2);
    size_t print(const Printable&);
    size_t println(const __FlashStringHelper *);
    size_t println(const String &s);
    size_t println(const char[]);
    size_t println(char);
    size_t println(unsigned char, int = DEC);
    size_t println(int, int = DEC);
    size_t println(unsigned int, int = DEC);
    size_t println(long, int = DEC);
    size_t println(unsigned long, int = DEC);
    size_t println(double, int = 2);
    size_t println(const Printable&);
    size_t println(void);
[B][COLOR="#FF0000"]#include <stdarg.h>
#define PRINTF_BUF 80 // define the tmp buffer size (change if desired)
   void printf(const char *format, ...)
   char buf[PRINTF_BUF];
   va_list ap;
        va_start(ap, format);
        vsnprintf(buf, sizeof(buf), format, ap);
        for(char *p = &buf[0]; *p; p++) // emulate cooked mode for newlines
                if(*p == '\n')
                        write('\r');
                write(*p);
        va_end(ap);
#ifdef F // check to see if F() macro is available
   void printf(const __FlashStringHelper *format, ...)
   va_list ap;
#ifdef __AVR__
        vsnprintf_P(buf, sizeof(buf), (const char *)format, ap); // progmem for AVR
#else
        vsnprintf(buf, sizeof(buf), (const char *)format, ap); // for the rest of the world
#endif
                if(*p == '\n')
                        write('\r');
                write(*p);
        va_end(ap);
#endif[/COLOR]
[/B]
#endif
For testing here are bootable XXDP and RT11 RX02 images that I have created and tested with.
They are in this google drive folder: https://drive.google.com/open?id=0B7Csc-dWWfTYR3plTmtWd2VtWlU in the 'RX disk images' subfolder.
You can just download and copy them to your microSD card (preformatted as FAT32), and then thru the menu command interface:
0 RT11.DSK
1 XXDP.DSK
w
which mounts RT11 on unit 0, XXDP on unit 1, and then updates/write the setup file to mount these images at startup (instead of default images RX0.DSK and RX1.DSK).
Note for the Arduino IDE monitor window the current software expects the monitor window baud rate to be 250,000 baud (as fast as the Arduino will go) and 'carriage return' line ending.
After the above setup, you should able to then 'b dy0' (or whatever your PDP-11 needs to boot from DY unit 0) and have RT-11 SJ boot from DY0.
Don
