Okay I finally got around to setting up the two 1.2mb 5.25" floppy drives I have here in my 486 at the same time last night to start testing... All appeared well with the first diskette, then I got some weirdness I'll explain and see if anyone can offer some insight.
I have two 1.2mb 5.25" floppy diskettes.
I have two (different brand) 5.25" floppy drives, both 1.2mb.
These diskettes were both included with some old software I don't care about and I just wanted them for formatting and testing.
Diskette #1 (labeled Disk 1 of 2 in the software).. if I place said disk in the 5.25" drive with a grey face plate, and tell dos to start formatting, it will start formatting, and complete with zero errors, no bad sectors and I can write data to said diskette. If I place disk 1 in the second drive with a white face plate it will start formatting and come up with "Track 0 bad or disk unusable".
At first I thought "Great.. I have a bad floppy drive that won't format." but.. then I pulled out Diskette #2 (labeled disk 2 of 2 in the software set) and put it in the second drive with the white face plate and it started formatting, and completed fine, no errors, no bad sectors. After format I could read and write to said diskette in that drive.
I then removed that diskette, put it in the drive with the grey face plate, and it would start formatting, complete, no errors, no bad sectors. Tried reading and writing from it, no problems.
Removed disk 2 and tried the white face plate drive again, started formatting again, completed, no errors no bad sectors, read and wrote fine.
So... I then tried disk 1 and it again threw errors in the white drive, but formatted fine in the grey drive.
I'm kind of stumped here... is my grey drive good and the white one bad? Do I just some how have a bad diskette? I don't have any other 1.2mb floppies in this format to test with. I just thought, if both drives worked correctly, they should be able to format any "good diskette with no bad sectors" at any time.
I also have a 360kb 5.25" drive I'll start trying to test later today, and see what happens with it.
