Trying for two drive at once on tge same cable.
To me, the attached photo should be right for jumpers as the second 5.25 drive. i am using a cable with a twist with this drive on the end and a later model 3.5 as the a drive. When connected, the 3.5 stops working but the 5.25 does.
bios values are sensible but the 5.25 is a in dos and 3.5 is b.
is it the cable twist? Or can I not remember something obvious from 1995?
TIA,
Brad
TIA,
Brad
