waltermixxx
Hi there, I was wondering if there was ever a solution to creating a working boot disk for the KAYPLUS rom.
I created a rom, and tested it without a boot disk, and I get the Monitor * prompt, and I was able to examine memory,
change boot drive etc.
it was very cool.... ROM working - Yup!
Then i went to the process of creating a boot disk....
Tried to run KAYCNFG program and I had the same issue most folks have had, 63K is too large.
I also tried the movcpm 62.00 command, and movcpm6200 and that does not seem to work either. Seems to just hang.
is there a version of movcpm that works on the kaypro so i can create a smaller version of cp/m for the KAYPLUS rom?
is it possible to bypass this portion and use a ready made 6200.sys file?
just wondering what my best option is...
I am unable to currently create a disk from an image, as my Tandy 1000 sl/2 eeprom seems to be pooched so the computer will not see the b: drive for some reason... so I am unable to create the disk from the image...)
is there a guide to creating an image from a 1 disk drive dos system?
I did successfully burn and install, and generate boot disks for the TURBO rom, but I wanted to mess around with the KAYPLUS rom as well,
i like the monitor, it's cool...
Cheers.
I am also open to offers to have a formated kayplus boot disk sent to me, i could paypal for the expense.
I am in toronto, ontario, Canada.
Kaypro 4/84
cheers.
postal code: M5S 2X9
Cheers.
cheers.
