TangentDelta
- Joined
- Jan 24, 2015
- Messages
- 41
Hello! I recently acquired a Kaypro 10 "83". I'd like to get put a KayPlus BIOS in it, but in order to do that, I need to get a working load of CP/M going first.
The machine was shipped to me with the drive safely parked with SAFETY.COM. On the load of CP/M 2.2H it had when I got it, FINDBAD was not reporting any bad blocks on the A partition, but the B partition would always give me bad block errors. In my experimentation, I stupidly formatted the hard drive and lost the working load of CP/M 2.2H that it had.
I have the full set of 8 CP/M 2.2H floppies, and I found images of them online. I'm able to boot to the first floppy, and it immediately starts the EX script. Once it does its cursory drive check, it attempts to run PUTSYS.COM and immediately gives me a "DRIVE WRITE FAULT" message and locks up. I ran the FORMAT.COM utility on user 13 with the correct parameters (1,1; 0,3; 0,305) and got about 40 bad blocks during the format. I rebooted the system and tried to load CP/M again, and got the same "DRIVE WRITE FAULT" message.
So, at this point, am I looking at a bad drive? Is there a low-level-format routine on the hard drive controller that I can jump to with a monitor?
