Hi,
I have a Kaypro 2 that won't boot. There was a CPM disk in the A drive, but it looks like the surface may be scratched.
Symptoms:
- Nothing on display even when adjusting brightness.
- Both drives are lit up and the power light is lit.
Observations:
- Neck on the crt is glowing.
- The large Rifa cap is blown on the power supply, three caps are showing shrinkage, but no signs of leakage on the board. Someone wrote "Bad PSU" on one of the aluminum fins. No signs of after market soldering done on the board.
The power to the main board at the connector is showing 4.8V, 11.84V and -12.4V without the board connected.
My plan is to replace the PS with a modern replacement and check the monitor board for broken solder joints.
Any other suggestions?
Thanks
Symptoms:
Observations:
Thanks
