eight088
Hey guys
I recently got a Kaypro 4 and I'm having problems with the keyboard. When I first powered it up, it came up with the usual insert boot disk screen and I also noticed that the keyboard also seemed to work (caps lock light would go on and off with each press and the speaker would also click when I pressed a key). So I got pretty excited that I have myself a working Kaypro, so went to my PC and made a boot disk for it.
After making the disk I then attempted to boot from it and success! It worked! Thinking it was working, I went to type in a command and they keyboard no longer seemed to be responsive. The caps lock light is always on whenever the machine is turned on, and no keys work.
After looking at some schematics, I tested the cable first and seemed to be okay, but there seems to be no signal coming from the keyboard to the SIO chip. (Or the hex inverter). So leads me to think it's an actual problem with the keyboard. I don't have much in the way of diagnostic equipment, but I do have a dmm and a diy logic probe (really need to get a better one though). Looking at basic things first on the keyboard, I've noticed that a couple of diodes have a voltage drop which is the same in both directions. One reads 0.5v and the other reads 0.02v (dmm in diode mode). Reading them in ohms, one is open circuit and the other is 46ohms, in both directions.
Is it likely a faulty diode is at fault? I didn't think diodes go faulty all that often, but they might be worth replacing? Only problem is I'm not sure what type they are, and I can't find a schematic for the actual keyboard.
Thanks
Thanks
